Over the past couple months I have let the truck sit over the weekend and noticed come Monday morning that it's dead. So to troubleshoot I charged the battery and disconnected the negative battery cable and let it sit overnight. Reading with my meter I notice that the voltage went unchanged at 13 volts. Also had the battery load tested at AZ and its good.
Last night I used my multimeter on the 20 amp DC scale and found that I have a 3 amp drain somewhere.
Does anyone know of any common areas to start checking before I spend a lot of time pulling each fuse?
Some of the common areas I have read about include the starter/alternator/TBC 3 fuse?/ HVACB / etc...
Also, if I pull the MEGAfuse that goes to the rear fuse block I believe I will be effectively narrowing down the search to half of the systems.
Much help appreciated.
