bass remote
Ericw259
10
I was thinking about a spot to place a bass remote and was wondering if anyone has tried to mount it behind the trailblazer plug that is in the spot where the 4 wheel drive switch is.
BO TIE SS
Here's where I put mine.
MAY03LT
Delmarva
I don't think I've seen one mounted there. I've seen some other stuff (switches, voltmeter, etc) but not a bass knob.
FWIW I put mine in the console.
YOUNG
If i had a bass remote installed which i need to do.. I would try to mount it in between the seat and middle console, on the driver side of console, near the shifter area. so it would be easily turned up or down while driving.. :undecided:
MrDJ
Waxahachie, TX
I wouldnt see why that would be a problem. I have also seen switches and other things there so there is obviously enough room for something. Will you be buying a bass knob or building it yourself? I built my own. It was a little larger than the other ones but I spent about $5 in parts.
Also, will you be grinding down the picture on that plate? A knob right in the middle of it would look a little off IMO.
MrDJ
Waxahachie, TX
I have a write up of a DIY Bass Knob. PM me and I will send it to you while I try to figure out how to post it on here.
Ericw259
10
I was also thinking about placing it on the right of the light switch because the black panel is blank there
MrDJ
Waxahachie, TX
I have thought about putting one there. You just have to make sure you get a small enough potentiometer. The ones I have built for my TB are a little too big for that spot.
jvest
