98tsiawd said:
Hey guys I'm getting ready to install my super cooler and was wondering wether or not I should use the fittings that come with the kit, or just cut the tranny line, flare the ends, put the lines on and call it a day. Do you guys recommend using the fittings?
Thanks for the help
I did a google search for the B&M 70264 cooler and the picture showed a couple of variations of a screw on connector with hose barb.
You will not be able to attach these to you radiator. Our trucks use special quick connect type that is not compatible.
What I did to install my Tru-Cool 4589 was to cut the tranny line on the DRIVERS side at the bottom of the radiator. I left about 4" to make it easier to work with. The flow of the tranny fluid is Tranny to Passenger side radiator, though the internal cooler in radiator, out radiator and back to Tranny. The new external cooler should be in the return line to the tranny, that is why you cut the Drivers side.
Once you cut the line I use both a male and female compression to 3/8 pipe thread. One of each keeps the flow always going in the same direction if you ever disconnect the lines. Once you have the compression fittings installed you can use the appropriate pipe thread fitting to connect to the hose that goes to the cooler. Some folks have had trouble with the compression fittings leaking but I have had none of that.
By the way when you are doing the cooler why not change the tranny fluid (14 liters) and filter. If you go into the tranny pan it is always a good idea to put in a drain for the next time, it is so much cleaner. There are several write ups on doing this, if you are interested let me know and I will dig one up for you.
Here is a link to pics of my install, hope this helps
My tranny cooler hook up with pics - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Good luck, not too difficult but will still take 3 hours if you do the tranny oil change and filter (make sure you get the proper filter there are two). You can go to your local GM dealer and they will tell you from your vin whether it is the long one or the short one.
