NEED HELP Automatic climate control
corky
77
Portland OR
So I can't find a lot of info on my problem, most of it doesn't apply. My a/c works find when the outside temp is in the 70s bit will work for only 10 to 20 minutes when it's above 80, the out side temp reads correctly, the little fan need my ear appears to be functioning, my freon press reads right and there are not any leaks. Once it shuts off it won't go come back on for quite a few hours, I have ordered another control head but haven't received it yet, any ideas or people that have had the same problem find the fix. When it happens the compressor pulley is not engaged, the fuses are fine and the blend doors work properly.
7,714
If it is STILL located in the same spot on your 2003 Trailblazer 4.2L SUV as is depicted in this Video...Try changing out your Ambient Temperature Sensor after considering this Guy's experience with successfully reconciling a similar "Phantom Temperature Change" Behavior:
TJBaker57
2,900
Colorado
... there are not any leaks. Once it shuts off it won't go come back on for quite a few hours,
What are your high and low pressures and at what ambient when read?
Do you have an OBD adapter? You can see the high pressure with one of those.
If you are at highway speeds does it still shut off after 20 minutes or so?
4,023
I'd say your clutch is going out. I had the same sort of issue, changed the control head as well (but it had issues) and it still did the same thing. About 6 weeks ago I changed out the compressor and it's been mint ever since.
576
Central Pennsylvania
Prior to changing out your compressor, consider removing the air-gap shim. I had dissimilar symptoms but removing the air-gap shim has kept my air cool for over 8 years.
Reactions: Mooseman and Matt
corky
77
Portland OR
All my driving is at highway conditions, going to work in the afternoons when it runs for about 15 minutes coming home at midnight it runs untill I get home which is about 45 minutes, they put the gauges on it at work and said the high and low were fine, just frustrating that it works great when it's cooler out side than when it's hot, and the outside temp gauge appears to be reading correctly
corky
77
Portland OR
Not familiar with an air gap shim, is it behind the clutch
TJBaker57
2,900
Colorado
Well that lessens the likelihood of it being an airflow through the condenser problem or a high pressure cutout problem and maybe even the airgap issue as from my own experience all of the above seem to occur more often at high ambient temps and lower speeds when the high side pressure shoots up and the system is generally under more stress.
I will have to say that without actual numerical values, "just fine" doesn't carry much weight as a diagnostic tool. Admittedly, I am not so experienced in the automotive A/C arena, however I have been in the residential and commercial A/C field since 1984, and I see an alarming number of technicians who don't really know how it all works! I am a big fan of gathering hard data to see just what is happening at realtime rolling down the road.
budwich
2,044
kanata
you need to get access to the controller and with a meter find out what's up... but at this point, the one test that you can do is meter the connection at the compressor clutch. do this when you know it is working and again when it stop... basically disconnect the plug, measure the resistance towards the clutch and do the same towards the controller... compare the results at the two different "events".
one question: when was the AC last serviced?
Dec 5, 2011
576
"Yes" - see @Mooseman 's post above.
Bonus: it's free! (Excluding your time.) While I had mine apart, I cleaned up the clutch mating surfaces a little with a wire brush on a dremel-like tool. While I stated my symptoms were dissimilar, they weren't completely different either. The hotter it was, the less likely it was for my clutch to engage properly. The dead giveaway for mine was a brief, high-pitched "chirp", that was the sound of the clutch attempting to engage for a moment and the magnetic force not being strong enough to hold it engaged. This sound occurred I believe on a 9-second (ish) cycle. Regardless, it only costs "time" to try and could prevent a high-dollar repair that would be a lot more lengthy.
chirobo1
