Apparent Fuel leak ... any common starting points?
jmonica
387
Hamburg, NJ
Hey Guys,
This is kind of a random question. Probably a dumb one but I love coming here, as I have over the years, and for what it's worth, I'm grateful for all the help I have received.
So as I exit the vehicle ('06 Envoy SLT), I smell gas so apparently there's a leak. Nothing under the vehicle that I can see yet after crawling under it, but haven't put it up in the air yet. It's been happening for about a week.
Like I said, this is a fairly random question so I apologize for that. I'm bored to tears at work so thought I'd ask and see if anyone has any good places to start looking, meaning is there anything that seems to be a common failure in this department?
As always, thank You!!! Stay cool out there!
If you're in the rust belt, it could be your fuel pump top or lines. It might just be a pinhole for now with fuel just pooling on top of the tank but would get worse.
Reactions: Matt and jmonica
8,053
It could even be your fuel fill or vent lines.
jmonica
387
Hamburg, NJ
Thanks Mooseman (As always). That gives me a place to start investigating. I appreciate it. Is it worth posting what I find or is this too random of a problem do you think?
It's a fairly common problem and already documented. You could do a "Investigating fuel smell" writeup with your results if you want.
Reactions: jmonica
jmonica
387
Hamburg, NJ
OK, I most certainly will. Also, at some point I will become a paying member. I promise. It's the least I can do. I'm sorry that I haven't shelled out anything as of yet. Me = 💩!
NJTB
612
Flemington, NJ
If the smell is near the drivers side rear, it's either the fuel filler neck or the lines on top of the tank. The filler neck can be checked from under the car, the lines you have to drop the tank.
On mine, it was the lines on top of the tank and I had to buy the lines, fuel pump and locking ring. The lines were so rusted to the fuel pump they wouldn't even come off.
Then about 3 years later the rubber hose on the filler neck split so I had to replace that, too.
I remember when the pump tops and lines were made of plastic. Was so much more durable and easy to remove. Guess there wasn't enough money to be made :frown:.
Reactions: JerryIrons
Firebaugh86
