My 04 Envoy is currently flashing the Airbag light 7 times on startup, which is normal.
But it then comes on solid thereafter. Indicating a problem with the system. Although there are no codes being set.
The seatbelt light is not flashing at all on start up, or if i drive without the seatbelt plugged in.
Which indicates a problem.
I have looked at some wiring diagrams, and both of these items are connected to the Inflatable Restraint Sensing & Diagnostic Module, that is said to be under the rear of the centre console.
I'd like to start by checking the ground on this unit and supply voltages.
But before i tear out the centre console, can onyone else verify that this is the actual location of the unit.
Or if you have fixed these problems in another way, please explain.
Thanks
Thanks
