Good morning,
I'm going to be aiming my headlights since I got a replacement set of housings. I noticed on the plastic trim cover over the radiator, near where the headlight adjustment screws are, there is a marking with a picture of the headlights and 1.25% molded into the plastic.
Everything I've seen has said that there should be a 2" drop from the center of the headlight lens compared to the actual bean hotspot output on the cross section on the wall. Does this mean on the Trailblazer that the drop should be 1.25% of that 2" instead? Its a 2002 LTZ.
Any input would be ideal. Thank you.
Picture pasted below for clarity.
