AC turns off truck
nichellem
2
When I turn on the AC stall out at idle intermittently. This has been happening since May 19th when I decided to turn on the air when I went to New Orleans. Yes, I was in New Orleans with no air and lived through heat of Chicago resently.
RayVoy
939
Try a search and read some of the many threads on cleaning the throttle body.
McGMT
621
Welcome to GMTNation.... Clean your throttle body... (The #1 thing said on this forum)
ksimm92
166
I ran into what sounds like the same thing not too long ago, as others said I cleaned my TB and good to go! :wootwoot:
You should have been able to leave it on anytime you're above idle. Did you try that? You may have done a lot of sweating for nothing. :frown:
If AC kills the ending at anything above an idle, you may have something else wrong. But clean the throttle body and let us know. Good luck! :cool:
Gump2773
147
and if cleaning the TB doesnt work, the #2 answer is plasti dip it! :rotfl:
jonu
