AC question
Nizar
65
hello
is that normal that the ac compressor is not always engaged even if the fan speed is set on 3 ? and is that normal that the compressor takes some power from the engine ? coz sometimes its makes the rpm to fall from 2 to 1 :S
Nizar said:
hello
Yes.
Yes.
But the RPM should stay constant. You need to clean your throttle body. Procedure has been posted.
Nizar
65
Yes.Yes.But the RPM should stay constant. You need to clean your throttle body. Procedure has been posted.
thank u my throttle body is clean but i think i need to change the spark plugs coz they are rusty and dirty ,i changed them last year but this winter was very bad and soooo much water on the streets and there was some water into cylinder 1 and 2 so i think its time to change spark plugs
jzouaoui
