Hey Guys, I'm not sure I even want to open this can of worms. I don't know enough about A/C systems to now exactly what I am doing. Just what I've read on here. I replaced the A/C compressor about 1.5 years ago along with everything else I was supposed to replace. I flushed the system and really tried to do everything by the book. The AC blew kind of cold. Then I parked the vehicle for a year.
Skip forward to today. The AC clutch wasn't engaging. I jumped the relay and the clutch engaged so I tried charging it, which kind of made it work. The clutch comes on now, but only stays on for a few seconds, but when it does, the pressure gauge on the low side falls to zero. As soon as clutch disengages, pressure goes back up. So dilemma one is I have no way of knowing how much refrigerant to add because the gauge goes to zero when clutch engages which is when the can says that I should check that the pressure gauge is in the green.
It definitely took about a half a large can of R134a but obviously I have other issues and it doesn't even try to blow any cold air out the vents at this point.
I might have more info if I could find the darn Blue and Red Gauge set that I bought a year or two ago, but it's mysteriously disappeared.
Thanks in advance and hope al of you guys are doing well!
