My AC quit yesterday on my 2008 TB with auto controls. The "snowflake" was lit and fan going but no AC. Of course, no compressor activity as torque showed no changes in the AC pressure (normally functions well). I did a quick check of the GM SI for fuse locations ... two in the rear fuse block (SI indicates 38, 39, but vehicle box indicates 36,39... both 10A). Anyway pulled both, put back one (39 I think), still no display (somewhat expected) but there was a bit of noise somewhere up front (relay like maybe). Put back 36, display appears and looks "normal" (like it always is). Start the vehicle and got cooling again...yippy!!! Monitor with torque shows "normal" pressuring.
I suspect a faulty actuator might have caused the issue as they are all original on a 260kkm vehicle. Hence, the question: can an actuator cause the AC to not operate / energize the compressor? Seems a bit of a "stretched" but just wondering. I am going to monitor things a bit closer to see what's up. The compressor /drier were replaced about 3.5 years ago by garage (old compressor had a clutch issue).
I guess that perhaps a "poor fuse conn" could cause issues with temperature readings of the control such that the unit "thinks" no AC is required maybe (although the setting on display did indicate my temp request of 18C) or possibly the internal cabin temp sensor was saying it was below 60F? I don't know what that reading was / is as torque doesn't have a pid for that (as far I know). Comments?
