Zapp Brannigan
- Joined
- Feb 16, 2012
- Posts
- 202
For starters, I have an '05 TB LS.
I had been running into the power fluctuation issue, I did my homework, and did the following
http://gmtnation.com/f17/what-did-you-do-your-gmt-today-822/index50.html#post53031
http://gmtnation.com/f17/what-did-you-do-your-gmt-today-822/index52.html#post54180
Did the Throttle Body, and Replaced the Secondary Air Check Valve (P0410 code).
Things were ok for a short while, then power fluctuations began again. Not only did power dip down, but on several occasions my power cut out completely while driving, car appeared to "reset" then power came back on. Not sure it this was an Alternator issue.
Now, I have noticed that sometimes when I go out to my vehicle, put the key in the ignition, there is no power at all. I go, check the battery, all connections appear fine, and randomly power is restored and I can drive.
Today I hit my remote to unlock the truck, it did the first unlock, then nothing (could not unlock the other doors). I opened the drivers door, never even put the key in the ignition, and saw the truck "reset".
After this LAST issue this morning, my radio (Head Unit) operates, I have sound going through my sub and speakers, the power light shows the HU as being on, but the display to the HU is blank.
I was initially just pissed I was having issues, but now I am concerned for my safety having either electrical issues, or a computer issue.
Thoughts, what it might be, solutions?
Thanks in advance guys!!
