Where it stands now 3/23/14
2.5 markMC The Lift Meister
Stock springs and struts
1.5 wheel spacer (no adapter) stock wheels
235/70/16...
BONE STOCK 2012
on 245/70/16...or 245/75/16. those are on the Rover now. They just fit on that thing. haha
Brush Guard Summer 2013
Installing the rear lift.
The TB with just the rear lift and spacers
the front strut and springs with Lift
Top view of strut springs and lift.
everything installed
We came along a little issue that turned out to not be a problem at all.
once installed the "wishbone" rubbed against the spring and the sway bar also rubbed.
Once the wheel was back on and the truck was lowered the clearance came back and nothing rubs =) YAY...i get so worked up and worried. Its my only vehicle.
We had another issue too. the CV joint popped out...we popped it back in then it happened a second time (youd think we'd bunjie it before hand...) the boot popped off. So, thankfully we had a clamp around and we raised the lowwer control arm to align everything back up, pop the CV back in and put the boot on. sigh
All Done...for now. Getting tires soon. =) cuz my little 29's look a little silly and I still need a bit more ground clearance.
