2004 I-6 SWB manual HVAC control. Everything worked correctly but I was really getting annoyed at having almost all lights on the control head out. Tried to take it
apart but could not get the slider knobs off and almost destroyed them. Ordered a new Dorman? unit from Parts Geek, but got busy with life and didn't try to install
for a few weeks. After installation, there was a programming procedure to follow with included instructions. Well I followed the wrong directions and had hot air coming
out instead of cold and vice versa. Disconnected battery, waited a bit, reconnected and reprogrammed. Now hot and cold working properly. All Good? Not so fast.
Now there is no relationship between the control knob setting and which vents air is coming out of. Starting full CCL, on dash vent position, air comes out of floor vents.
Turning CL to floor position more and more air comes out of dash vents. Continuing CL, air starts coming out of defrost vents, but never stops coming out of dash vents.
Air comes out of side window defrost vents only when control is in dash position with air coming out of floor vents. AAARRRGGGGHHH!!!! I could live with this but it
is really annoying. I did try pulling fuses, disconnecting the batery, opening and closing door, and everything else I could find in other posts. Please note that everything
worked properly before I installed the new unit. Any suggestions? Get a used unit from a U-Pull It and hope lights work maybe?
