Hello,
turned on the A/C today and the system would only blow hot air. I checked all fuses and they are all good. Opened up the hood and rolled down the windows, turned the a/c on and I can here a click and there is a drop in the engine idle. I jumped the low pressure switch and the I can hear the compressor running. None of the a/c lines are cold when a/c is on. I'm looking for some ideas that I might have not tried before I bite the bullet and take to a shop.
Now we know you're not THAT sort of goof, we know you won't do any more damage. A low pressure situation shouldn't even cycle on for a second, IIRC, but the best thing to do next is check pressures. Buy gauges if you want to be a bit more self-sufficient, but evacuating and recharging a system takes a lot more than gauges alone to do well, as you know. The fan clutch could be totally dead and the AC system should at least start up and get the receiver/drier chilly. It may not get rid of adequate heat to get the cabin cooled down at idle on a hot day, but the fan clutch isn't as vital a part of the system as you might think. At 140K, I bet you just have a leak.
I have been a member of the Trailvoy forum for as long as I can remember and that as helped me save a lot of $$$ on repairs that I have been able to do myself. Now that I am a member of this forum, I hope my string of luck can continue! I will take it to an A/C shop and see what they can do for me. I will post with more info once I have the results.
I figured I better move or else. Glad I read that post, glad I am here, and hopefully I don't have to shell out too much to have cold A/C this summer. I do have to say, that anytime I have had a problem with the vehicle, your answers on the TV thread have always been the most help. I'm glad that I can always do something myself. I love my TB and as long as I can keep it running, I'm going to keep it.
