NEED HELP 97x ignition switch problem
kenmarion
1
Greensboro NC
I'm hoping you can help on a similar problem., I have a 2007 97x. Battery drained after sitting for two days ( dash lit up but not enough juice to crank) and after three days battery completely dead (0 volts across terminals). I suspect ignition switch, which now has key locked in it due to anti-theft. Questions: 1. Does my initial diagnosis of ignition switch sound correct, and 2. Any ideas for source for replacement ignition switch. Appreciate the help.
Maybe. Need to do a proper diagnostic first. Have to find where the parasitic power draw is occurring. Is the battery good? Usually the key won't come out if you're battery is low.
A recycler, pick-a-part or eBay. They are NLA new.
MissCrutcher
