Hi All,
I'm at wits end and in need of help, Have an 2003 Trailblazer LT with a 5.3 liter, 180,000 miles: at high speed engine will dog right down to about 20-30 MPH, give it gas and it sounds like i'm flooding the engine give it light gas and will stay running and sorta coasting for a few miles but will eventually come to a stop, turn it off and in 15 minutes will start back up and run for a little while before it happens again. seems the only constant is the gas is between 1/4 and 1/2 tank. Lasat 2 times this happened i coasted to gas station did not shut it off filled tank and everything was fine till I reached the same gas level of 1/4 to 1/2.
I have replaced TPS and cleaned Throttle body, fuel filter and fuel pressure regulator
Dont know what else to do!
