Replaced the Actuator and the front axle disconnect. Can hear the front actuator and the transfer case motor working. Can feel the front wheel engage by spinning will jacked up, and wife moving the switch to 4wd. The front driveshaft also spins the front wheels when in 4wd. Try and move the switch to 4lo and service 4wd light comes on with no light over 4lo, remains at 4wd. Move the ignition key to off and switch to 2wd then turn the key back on makes the motors work and the light go off. My guess is the transfer case clutches are worn.
After removing fuse #8 under hood will go to 4lo, still no front wheels.
