I would expect that if it rotated to an invalid position the encoder sensor would report the out of range value to the TCCM and a code or the like would result. Assuming the encoder sensor is functioning properly.rotate to an invalid position
can't imagine how that can happen. So I have to find another encoder.
could a Scosche box send spurious network traffic and cause the tccm to shift?
very different from the original
to the PYP and get a tccm and an encoder ring
There is an NGK/NTK TM0003 which is a cross reference to the acdelco.
According to the manual it is programmed with the gear ratio and tire size.
HAH! Twins Mine has the same build date as yours! What are the odds of that?
How do you determine if you have the defective range shift collar? The history report just says that some of these vehicles had the defect. Although I imagine if it really was defective it would not have lasted 18 years.....
Neat trick with getting the TCCM numbers. I'll have to try that when I get my system reconnected.
A u1000 comes up with torque, but not with car gauge pro. I'm puzzled by this because the engine is running well
What was the solution to recovering the TCCM from shutdown? I'm in the same boat. Lights on startup then nothing.I guess I have to try the parts changing routine. I'll start with a tccm from a 05+ - that will have revised firmware. It appears that the tccm has two parts of the firmware - the OS and calibration data. I would even speculate that the tccm may have been paired with the TC at the factory, but the company is out of business so there's no way to find out.
After installing the relubed encoder motor I now get a c0327 so I'll have to remove it again and check what went wrong. Also, this seems to have caused the tccm to shut down completely and I have no lights on the mode switch ( except the test on startup).
I just can't get a break
Mine totally diff Borg Warner 4484.(GM software in both cases) It was the similarity of the TCCM lockout that caught my attention. I'm in the middle of a H2/Duramax/Allision conversion and when I tested the TCCM was working (unfortunately for me, was testing encoder motor not attached to TC) With continued testing, I then got completely locked out as expected and specifically described by DTC c327. Nothing I did could have led to the TCCM going bad. I sps'd it Friday but only the calibration not the os. It did not reset. I'll reprogram both and see if I can get lights back on, then try to get them insync and test with TC connected.What vehicle? If this is a 2002, skip the whole thread and look for a TCCM off a newer vehicle. High failure rate for 2002s, and those are exactly the symptoms of a bad TCCM.
Agree, but unfortunately not many techie's in the H2 forums. Yes TCCM's are different but encoder channels work the same with regards to signals. There were two on this thread that seemed to have in-depth knowledge on the subject and hoped to PM them but I didn't find an option to do so.I see. You are in the Trailblazer/Envoy forums. The best thing is to start a thread specific to your case in the H2 forum. While both have GM software, the TCCM is completely different. On the 2002 Trailblazer/Envoy, lights coming on for test phase and then all going out indicate a defective TCCM.
You can start a conversation with another user by clicking on the user's name and then selecting "Start conversation" (note: you must be logged in). A response to the conversation will show up as a message (the conversation/message icon is located at the top right corner of the page).There were two on this thread that seemed to have in-depth knowledge on the subject and hoped to PM them but I didn't find an option to do so.
Well, it just showed up - Thank you!That option not available to me
