can anyone tell me if a 4 L 60 e transmission out of a Yukon there is four wheel drive work in a Rainier that is all wheel drive
It's an 01 and an 04Depending on the years, yes. 07 there was an internal change. V8 to V8, no problem. V8 to I6 you have to swap the bellhousing and torque converter.
Okay I swapped out the transmissions and now I'm not getting any gearsI know for sure that the 4wd and AWD tailshaft and mating pattern are the same within the same platform however not sure if it is the same with the Tahoe's larger transfer case. The mating pattern may be different. The 01 internally should be the same as the 04.
Only going on the information provided. Did you check the fluid level with the engine idling?Okay I swapped out the transmissions and now I'm not getting any gears
