4.2 running on four cylinders
zkepler00
8
Florida
Trailblazer troubleshooting:
This all started with a po203 code for injector 3
The issue: It fires right up and the cylinders that work run smooth, cylinders 3 and 4 do not run I believe it to be electrical related but am unsure
Whats known: it gets spark and fuel, and all coil packs are receiving the appropriate 12 volt power
What I've checked/replaced: its not coil packs, spark plugs, injectors, cam angle sensor, computer
Next things to check: injector harness, wiring harness, crank position sensor, vvti sensor, maybe knock sensors, compression test
7,733
(1) Look for any Hidden Damage from Mice Gnawing somewhere along the length of the EFI Harness and right at the Harness to PCM Main Connector. Also check the Wire Bundle-Harness leading to and from the C2 Connector on the PCM:
EFI #3: PCM Connector C2, Color PINK/BLACK, PIN # 16 (Control Wire) Circuit # 1746
EFI #4: PCM Connector C2, Color Light Blue/BLACK, PIN # 8 (Control Wire) Circuit # 844
(2) After a "Scope-On-A-Rope" Lighted Probe check for confirming 'Powers and Grounds' on the #3 & #4 Cylinder Fuel Injector Circuits and making a second DMM Check to measure that the necessary DC Voltage is Nominal at both... If either EFI #3 or EFI #4 were stuck OPEN... with the Engine running, you might see Plumes of White Smoke coming out of the Exhaust while the Motor struggles along on 4 Cylinders at Higher RPM.
This might suggest a Blown Head Gasket.... BUT THIS WILL NOT BE THE CASE. If the White Smoke is present, it is just an artifact of having a constant stream of Unregulated Fuel being dumped into either the #3 or #4 Cylinders and adds to the Diagnostic Information to determine if either the #3 or #4 EFI would need replacement.
(3) How to Test for an OPEN CIRCUIT on the EFI System with Basic Tools and confirm that the PCM is NOT the Problem:
MEHMET ONUR
