4.2 i6 to 5.3 ls
Hi and welcome! Lots of knowledge available here if you get into a bind.
Will you be using an aluminum or cast iron truck block? A pre-game commentary with some details would be nice :biggrin:
Big west
16
Hi thanks for the welcome! I'm using the aluminum block from the 07 Chevrolet Avalanche LTZ I'm in the process of getting the donor truck brought to my shop. I don't know what ecu I'll be using just yet there's so many to choose from. The engine will be cleaned up with new positions rods and rings new cam from cleetus McFarland (bald eagle) it will be machined and put back together. After everything is in and working how it should I'll be painting the voy royal blue with heavy metallic. I'm pumped for this I am tired of reading about it and not seeing a complete project.
Big west
16
Do you plan on adding any power to it at all or just a quick rebuild?
I plan on turbocharging it to at least get to 500hp still want to be able to tow with it and daily her.I'm also looking for the T56 manual transmission but finding it hard to find one lol still looking tho and new is just too expensive lol. Might just go with the Asian AR-5, I have one already just sitting in the garage
Reactions: Maverick6587
Reprise
2,724
Subscribing :thumbsup:
FYI - I found a T56 near me. Guy wants $2800; it has some addn'l goodies. No idea about value.
PS: If you're looking to tow heavy, the 4L80 & successors will ultimately handle more than the T56 (I've already done some research, as I was considering this myself).
But if you're putting the M/T in mainly for 'fun', then have at it :smile:
Biggest problem for the manual trans swap is the clutch as the 360 never came with a manual. I think somebody did it once a long time ago on TrailVoy with the I6. There could be something that can be used from a Colorado, Canyon or H3 with the I5.
7,736
There is a Cool Chapter in this "How To Swap an LS Engine into Almost Anything" that covers installing Manual Transmissions, Clutch to Fly-Wheel Components AND Clutch and Brake Pedal Assemblies ...Well Worth adding to your Research Efforts for under $30.00:
Mike534x
934
I'm not sure if this is any different, but this person swapped a 6 speed into a TB SS. I think the only issue they encountered was having to reinforce the firewall, to handle pressing the clutch and whatnot.
Reactions: mrrsm and Big west
Big west
16
The 5.3 is about to be pulled out of its previous host more to com
I would definitely be getting this book
Maverick6587
730
Sterling Heights, Michigan
I was doing some research for my build this weekend. Looks like the Gen IV LS (at least the 6.0L) have stock rods and pistons that can handle up 1,000 hp. I assume the 5.3 would carry similar quality rods and pistons?
In the following video upgrade from a 6.0L to a 6.2L. He explains the hp capacity on a lot of the internals of the Gen IV LS.
I was going to completely rebuild my 5.3 at some point. I might just replace the heads with rebuilt ones and see how long she'll last. It has 230k miles on it as of now.
7,736
To Whom It May Concern:
"The Sloppy Mechanic" regularly takes "Junk Yard Iron" 4.8L and 5.3L Engine Blocks... and while living up to his 'namesake' ...he throws in a Camshaft and some LS6 "Blue" Valve Springs "Quick and Dirty" and then Turbocharges them up to around 800 and even OVER 1,000 Horse Power.
It sounds Crazy... but he could turn out to become your Best Friend by proving that the 6 Bolt Mains, Stock Cranks and Stock Rods are interchangeable between the 4.8L and 5.3L Motors and can withstand (almost) all of the abuse he throws at them.
I recommend watching most of his 5.3L Builds to get other ideas and suggestions on your Project... But for God's Sake... Just Don't adopt his Very Dirty Methods along the way for the actual Engine Build Procedures. This video shows him replacing a Bent Connecting Rod out of one of his Busted Turbo'd LS Motors:
Big west
16
Engine is dismantled and ready to be cleaned and heads resurface then resamembled. Sorry for not posting anything in a bit but I'll be posting more often from now
aaserv
408
N of Baton Rouge, La.
Any plan on what your going to do for motor mounts? My understanding is the 5.3's are no longer available and I know from experience the aftermarket 1's are junk. Im planning on swapping my 5.3 for a 6 or 6.2 next summer so very interested in this project your doing...
Reactions: Big west
Big west
16
Hi yes I have a shop that's going to be making me custom made engine mounts will post pictures of them when they are done
Big west
16
Engine is clean heads being ported valve covers painted. Project is going by smoothly
Reprise
2,724
Saw the valve covers -- is that a flake paint, or some of the crinkle stuff? Guessing there's ceramic in it, if you're putting it on valve covers.
Reactions: Big west
Big west
16
It's metallic high heat. Primed with hunters green to make sure that the metallic pops
aaserv
408
That not an LS cam is it? Looks like a regular small block chev cam. Don't think you'd be happy with those specs anyway if your looking for horsepower.
Just looked it up....That is a small block cam...
That's right with the distributor/oil pump drive gear on it.
  • Wow
aaserv
408
Those specs wouldnt get anywhere close to 500 HP if it did fit.
Lift is barely over stock. LSA is way to low. And duration is to high. 273LR HR12 is the number for a Comp Cam that will get you in the ballpark......After you change valve springs, injectors and run the biggest stock throttle body you can find It might get you to 400+ HP pre turbo.
Big west
16
Up date Time so I got custom made engine mounts and exhaust flange made locally. Engine mounts are made with 3/8" thick steel and exhaust flange is 3/8" thick mild steel will be making custom exhaust system. Still waiting for the wire harness to come in then it's full steam ahead. Also thank you for the support and information you guys have been an amazing help I'm also going another route with the cam 😊 thank you guys
Reactions: mrrsm and Mooseman
aaserv
408
I saw a comparison video awhile back. stock exhaust manifold vs short tube headers vs long tube headers. Difference between stock and short tube was virtually nothing. Go long or keep what ya got. Difference between an h pipe and an x-pipe was negligible also.....
I know Envoys are notorious for being hard to fit dual exhaust so will be interesting to see what you come up with.......
Reactions: Big west
I've been looking at the Sloppy Stage 2 cam for my Caprice 6.0L as it seems to be very popular and dyno tests show that it has major gains at all RPMs, not just on top.
Looking at the flanges, I would guess that you're looking at making headers? Have you looked at TB SS headers? I think there are quite a few options out there. Just watch out for 4x4 vs 2wd as most only work with 2wd trucks.
Reactions: Big west
Big west
16
Thank you my
Yes I'll be making my own headers to accommodate for the 4x4 and all that jazz already have an idea on how to route the exhaust system so I can have dual exhaust 😁
Big west
16
Just waiting for a few more parts to come in (ie) alternator, coil packs and starter then it's swap time. Custom made engine mounts made locally and they work with the SBC mounts fits perfectly, will be making my own headers and complete exhaust so everything would fit perfectly under the voy it's getting close y'all I'll have full documented videos out on YouTube once everything else gets here and the swap actually starts
Fishnbob
45
OC
Did you ever finish it?
And he hasn't logged on here since Dec. 2020 :frown:
The gist of this swap is you need practically a whole donor GMT360/370 for all the parts, including harness and PCM. You also need to consider the rear diff as the original 8.0 will die quickly behind the 5.3 . Find an 8.6 from another 5.3 GMT360 or a long wheel base GMT370. There may also be issues with making the 5.3 PCM talk with the original BCM, which may require replacing it and the harness.
Not an easy swap.
Reactions: Fishnbob
northcreek
3,322
WNY
Bummer, I’m getting a 05 TB I6 this Saturday, has a blown head gasket and I want to put in the 5.3
You might want to find one with a bad 5.3 and put a 5.3 in that. The swap is just too much grief to make something that already exists...:twocents:
Reactions: Fishnbob
Brianhvac
