3rd Brake Light connecter plug
Me007gold
1,106
So I have a new Avalanche 3rd brake light on the way, I want to make it TRUE plug and play, that way in case I ever need to I can just unhook the good one and put back the old one. Is this the plug I need to buy? the male end is the end going back to the body correct?
12047662 Delphi Connection Systems Automotive Connectors
img borrowed from blkshdw
10,665
Yes, that's the plug. OR, you could just do what I did, and get a few crimp on quick disconnects. Use a male and female on the Avalanche wiring, do the same on your old stock one (make sure they are crimped on the same way) and then put a pair on the stock wire with the opposite setup. :thumbsup:
Edit: Kinda hard to tell, but do you have to buy the pins for it too? Or does it come with them?
Me007gold
1,106
I know i could do that, This just seems easier, Shipping kills it though.
10,665
Note 5 lists a terminal number, I couldn't find it in the Mouser catalog though. I didn't see that this plug came with terminals for you to use, but if it does, then yeah that might be easier.
[PDF]http://www.mouser.com/catalog/specsheets/12047662.pdf[/PDF]
