2008 trailblazer no spark and no tach. I jumped a person, and they killed my blazer.
Crank shaft position sensor is good
2008 trailblazer no spark and no tach...
...Crank shaft position sensor is good
If the crank sensor is good, but the ECU doesn't "see" the signal...either the wire harness between the sensor and ECU is defective, or the ECU is defective.ECU does see the crank shaft sensor.
No spark or Tach after Jumping another vehicle
I did replace CPSJust because a ECU sees the CPS, doesn't mean it's good either. Magnet could be cracked internally, or a few other things.
"The" fuse box? Aren't there multiple fuse boxes?I checked every fuse in the fuse box with a VOM meter.
Ok... then the next step is to check for voltage at the appropriate fuse. Go from the result.I checked every fuse in the fuse box with a VOM meter. I wanted to check each fuse in the 2008 trailblazer and replace them if necessary
