Per the title, my blower control module seems to have crapped out on me today. Displaying what seems to be the classic symptoms, the fan continues to run at full speed with ignition off/key out/RAP off, and no speed control. Pulled fuse 35 (40A) to shut it off (pulling the 10A fuse and swapping the relay had no effect) until I could get back home and do a little research.
A quick summary of what I've learned (links posted below) is as follows:
Relevant threads:
Within those are two specific posts by Roadie (naturally) that are particularly valuable:
This one contains the FET part number(s) - plural because there is a more robust drop-in replacement for the original: http://gmtnation.com/f23/possible-control-module-problem-blower-motor-wont-turn-off-1440/#post44856
And this one contains a series of pictures of the various modules/connector styles: http://gmtnation.com/f23/04-envoy-blower-motor-blower-module-problems-277/#post4149
One piece info that I came across as I looked into this, which may be newer than the posts above, is that apparently there IS another aftermarket module available that solves the problems encountered with older blower motors.
This may suit those of you that believe that your blower motor is fine, or aren't comfortable with soldering a new FET on the old control module PCB, for what seems to be a reasonable $77, though you're still left with the connector/splicing issue. In the event you feel like replacing blower and control module, Rockauto has what looks to be a more robust control module by AIRTEX / WELLS for $20 less that may appeal: More Information for AIRTEX / WELLS 4P1516
Lastly, this pic from GM Service Info may help others locate the module for removal (the misspelling of the word 'control' is GM's not mine):
For me, I just happen to be heading to Kenny U-Pull in the morning to snag a RR marker light for a Pontiac Wave that got in my way in a parking lot last week
....I'll try to pull an old module or two to buy me some time to get the new FET delivered and installed.
Wasn't easy tracking that all down and getting my head around it, hopefully this helps someone down the road.
Cheers, and thanx again to the community at large for putting the info out there.
- The FET in the older style modules seem to fail as a result of poor contact with the thermal compound / heatsink. This makes perfect sense in my case, since mine failed pretty much right around the hottest part of the day. At the time, I was only running the fan ~ midspeed, and since my AC also has an as yet undiagnosed leak (and isn't functioning), the heatsink was likely unable to cool the FET sufficiently.
- The original part has been superceded. GM/AC Delco have an "updated" module that apparently doesn't get along well with older blower motors, requires specific power & ignition switching cycles to work properly, and has a different connector that requires some splicing/adaptation to install.
- People have found that when using this newer module they were often forced to buy a new blower motor to get proper functionality.
- The FET can be replaced in the original module, possibly offering opportunities for improving upon the heatsink contact, MUCH CHEAPER (~$6), and saving the hacking and wire splicing.
Relevant threads:
Blower Motor/Module? Problem - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
"There was not a software update but another part is now being supplied and so far with no unexpected issues. Click here for the new product link."
....I'll try to pull an old module or two to buy me some time to get the new FET delivered and installed.Wasn't easy tracking that all down and getting my head around it, hopefully this helps someone down the road.
