Hello guys. I'm having a problem with my ignition switch or body control module I'm not sure which. When I try to start the truck it does nothing no crank no start. But if I pull the relay out of the socket underneath the hood I can jump it and then it'll start but it won't shift. It does go into gear but it will not shift gears. However if I put a jumper wire in the back of the ignition switch connector giving a red wire on the bottom of the connector the 12 V that it should have to begin with everything works fine. Now, when I test the voltage on that wire with the ignition off I'm only getting about half the volts it should, I'm showing about 6 to 7 V, with a full 12 V on the other wire on the top side of the connectorwith positive voltage coming into the ignition switch. As soon as I turned the ignition switch on, all the voltage goes away from the wire on the bottom of the connector. I hope I explained that right. Has anybody else had this problem? Also, does anyone have a diagram for the pin out of the ignition switch connector? That would be greatly appreciated.
