Is this the symptom of a bad oil pump or oil pressure switch?
NGM93 Original poster Member Mar 3, 2020 1 Commerce, Ga Mar 3, 2020 #1 Is this the symptom of a bad oil pump or oil pressure switch?
C Cthornburg1972 Member Feb 6, 2020 22 Florida Mar 3, 2020 #2 NGM93 said: Is this the symptom of a bad oil pump or oil pressure switch? Click to expand... Do you hear any type of ticking noise? If not I would probably say a bad oil pressure switch or a stepper motor in the instrument cluster.
Ilikemy3s Member Dec 3, 2011 369 Mar 3, 2020 #3 if your oil level is good and there is no ticking, i vote for the switch. I have had 3 x 360 platforms and have had to replace 3 switches. Reactions: Redbeard
wstuckey1 Member Apr 11, 2018 457 Fenton MI Mar 3, 2020 #4 I had the same problem a little while ago, lost oil pressure at idle once it was warmed up. I replaced the switch and no more problem. Reactions: Redbeard
