SveinHa
I just bought a 2003 Tahoe that have been out of service for 5-6 years. It starts and runs well and I got it home yesterday (100km/60miles including a few long 8% slopes). There are so many electrical problems that I assume there are one or a few key problems that needs solving like grounding problems or similar. 10-15 years ago, I had a 2002 Tahoe that was working 100% but this one is a different ballgame... I knew, or at least assumed, that there were a few things that needed attention when I bought it but it was a bit more than I expected...
Things not working:
Anyone with some hints on where to start looking?
Things not working:
- Instrument cluster: The 4 gauges to the right in instrument cluster works fine occasionally. Did a refresh on solders on a handfull of resistors in the instrument cluster but I'm not sure it helped at all. At least one solder was bad. Battery symbol top right is always illuminated. Tach and speedo works fine. Background light intermittent.
- 4WD, hi/lo panel: Works every now and then but usually dead (buttons don't work and LEDs dead).
- Window motors: Works on rear doors from local panel but not on front doors. Passenger door window have a few mm movement occasionally.
- Central locking: Might work from passenger door but not from drivers door or when using key or remote.
- Radio: Never got any sound but display come and go randomly.
- Airbag: Warning light on. Message in mirror: "Passenger airbag off" regardless of seat occupied or not.
- Engine: Warning light on.
- OBD-II: My (cheap) Bluetooth OBD dongle lights up but the app (Car Scanner, AndrOBD) cannot find any ECUs. I'm about to buy a "real" diagnose unit and hope for a Black Friday offer on UCAN-II-C Pro...
