- Nov 10, 2013
- 4
Hi folks,
I have some observations and tech questions that I hope The Roady or similar educated folks could chime in on. It's an '03 ENVOY XL SLE 4.6.
yes, yet another case of "service 4WD" indicator in the instrument panel. I have read previous posts on this site and TrailVoy about slightly similar cases, but I feel this case differs from the rest.
When I move the selector from 2W HI, to A4WD or 4HI, it engages no problem. In neutral and stopped the 4LO engages no problem. Selector light properly illuminates in accordance to its position, no problem. While stopped and in neutral I can go through all of these selections flawlessly, hearing the telltale signs of proper engagement and disengagement. I mainly run in 2HI, and when necessary to trail or snow conditions I will engage 4HI or 4LO. I usually don't find A4WD useful.
This is where the problem begins: When I drive over 15-20MPH in a 4wheel position (any,) the infamous "service 4WD" light comes on. When this happens, I cannot disengage any of the 4WD selections....until I shut the truck off and restart. Then the desired selection is initiated, noted by the indicator light on the selector, and the telltale sounds of the engagement or disengagement for 2HI. I also noted a rubbing or honing sound similar to that of a dry bearing. This is predominantly on the drivers front axel area. But know the wheel bearing is in good shape. I have ruled out the TCCM, and the actuator motor, because they are obviously working.
I took it to Advance Auto to put it on the code reader, and it only came up with a missing wheel speed sensor code, and brake control module issue code. I assumed these are irrelevant to the issue at hand. I also noticed (though may also be irrelevant) a bumping sensation when I come to a short stop. However, with this collective evidence, is it possible there is a bad bearing in the front diff on the drivers side? Could this disengagement issue and "bump" be related to that, if that where the case? FYI its not any suspension issue, though I am lifted. All of the links and suspension parts are rock solid and fresh. Further more this is not a new issue, it's been this way since I got the truck, and just blew it off due to good weather. Of course the snow is flying now, and I want to play with my 4X4 in the snow. So I welcome any takers on any possibilities I may have overlooked, or if in fact my bearing thought holds any ground.
