Hello,
I have just purchased a 2003 Envoy SLT and would like to start off on the right foot; it has 170,000 on it so I would like to change all the fluids, plugs, wires, fuel filter and anything else that any of you would recommend. I have a couple questions for anyone willing to take a few moments of their time to make my new Envoy ownership a happy one.
1. Where is the fuel filter located? Is it easy to remove and re-install?
2. Do I need to remove the rear dif cover to drain the rear dif fluid?
3. What other fluids should I change, where are they located and how hard are they to change?
4. What else do I need to change? Air Filter, Plugs, PCV value, Plug Wires... did I miss anything?
5. It needs a new radio, can I simply pick one up at the wrecking yard and plop it in (same model)?
Thanks again for any help you can provide.
Phil
2003 GMC Envoy SLT 170,000 km
1998 Chevy Blazer 2 Door Five Speed - 446,000 km
Phil
Welcome
Spray it alot.....GM uses a generous amount of rust to ensure that they would never come loose by themselves.
