2002 Trailblazer, 4.2L I4. 187,000 miles.
As noted in my most recent thread here I just replaced the ignition cylinder and got the vehicle running again. This was also after an exhaust manifold replacement.
After finally getting the exhaust manifold bolts adequately tight and eliminating the light exhaust leak we could hear the vehicle ran perfectly fine for a combined time of about ~40 minutes over the course of a few days. No uncharacteristic vibration, no odd sounds, no notable issues to speak of.
Now, out of the blue, it has a slightly rough idle in Park. There's a light vibration that can be felt throughout the vehicle and hooking up an OBDII code scanner shows a P0300 misfire code. A quick googling tells me that about a million things can be the root cause of this code.
There is no uncharacteristic noise however - it doesn't sound like an actual misfire or bad cylinder ignition. I've had one of the spark plugs go out while driving once and it knocked severely and threw up the "STOP ENGINE" warning which this isn't doing, it's just showing the Service Engine Soon light.
Additionally when at idle the RPM's will gradually drop until the vehicle stalls. Once the RPM drops to around 650 the vibration becomes much more noticeable.
I have also noticed that turning the AC on/off at idle caused it to "choke" and nearly stall. The idle will go very rough for a couple seconds immediately after the AC is turned on or off then spin back up and it'll run fine. I don't remember it doing this in the past.
Suggestions?
Suggestions?
