xforbiddenone
- Joined
- Jun 5, 2012
- Posts
- 4
Well guys, I have a 2002 Envoy XL sitting around with two problems that just might be connected to each other.
Like many users here, I was having trouble with the rear HVAC actuators, the top vents don't work, and on a side note, on the center console where passengers can change hot or cold, fan speed and leg or head vents, The vent control will not move off of showing arrows pointing to head and feet.
Now, I've replaced both actuators in the back, and I'm still having the same problem. Did I end up with a bad actuator replacement, or does the center control have something to do with this? Switching from hot to cold appears to be working fine. And as mentioned, fan control works fine. I just cannot get air to come out of the top vents without manually changing the air flow.
I'm also concerned about the middle console not changing off it's little icon.
Where do I go from here, and what can I do about it? ( and yes, both problems were present BEFORE taking it apart )
