2002 cylinder liner failure? Just curious.
c good
526
My Envoy still running great, just a little piston slap before warming up. In my research on piston slap I noticed GM had a recall on "sleeve" failures for certain V.I.N. numbers/production runs.
I'm curious if my 2002 might be affected. Does anyone know where this V.I.N. info can be found? thx...
Matt
4,019
I knw for sure it was the early model 02's. Likely 01 build. My June 02 wasn't affected.
8,047
Its been so long, they wouldnt honor the recall anyways...
Those affected all failed early so none would still be alive today unless it's an ultra low miles barn find.
TJBaker57
2,897
Colorado
These were the breakpoint VINs I have seen. Mine fell in that range but as already stated it would have already failed long ago.
2002
Chevrolet
TrailBlazer
22100007
22358861
2002
GMC
Envoy
22100001
22358855
Reactions: Matt and Mooseman
c good
526
Mine does fall in that V.I.N. range. It is nice to know that when they failed they failed early so that's a good sign. Mine has plenty of miles past that. I was just curious. Thanks all for the input.
7,642
GM Atlas Vortec 4200 Engine Cylinder Replacement Repairs are possible utilizing the Melling Cylinder Sleeves Part# CSL331F @ $30.79 per Item available from RockAuto:
https://www.rockauto.com/en/catalog...l6,1398719,engine,cylinder+repair+sleeve,5312
The work requires THIS complete, unique R&R Kit from K&M Part# EN-45680-400 for the proper Removal, Installation and Upper Engine Block Surface Trimming of the New Melling CSL331F Cylinder Sleeves within tolerances (with a stock 1.50mm Wall Thickness requiring a 400 Grit Plateau Carbide Ball Hone for achieving a proper completion and prep for New Pistons & Rings) :
29545046088_56527305b7_c.jpg29545046158_a4c8df101c_c.jpg29545046238_0537b16e1e_c.jpg43415583041_a864335d06_c.jpg43415583181_eaccf97aa0_c.jpg43415583681_7757db2b81_c.jpg43415583791_30ee6a425e_c.jpg43415584251_821286cdd8_c.jpg43415584541_3b09874a47_c.jpg43415585701_b625efa629_c.jpgScreenshot from 2021-11-01 21-32-43.png
Occasionally, the Full or Partial Kits can be found on eBay, or ordered from Freedom Racing at a Premium Price Tag:
https://www.freedomracing.com/catalogsearch/result/index/q/EN-45680-400/
Although the problem of dropping sleeves has been eliminated since that initial run, if it does happen, I doubt that the block is reusable after the carnage of the sleeve making contact with the crank
c good
526
So if it hasn't happened by 190k miles, I'm probably ok? Has anyone heard of the sleeves causing troubles this far into the life of the engine?
MissCrutcher
