king_strut
Ok, so here are the details of my truck and the issue I have. It is a 2001 Chevy SIlverado 1500HD 4wd with auto a/c. I went to my truck the other day and turned the key on, fired the truck up and went to turn on the a/c. Nothing happened at all, no blower motor no compressor no lights on a/c control panel other than a/c on light which got brighter when I tried to turn the fan speed up and which also would not turn off neither would the recirc. Then, I noticed that I had no tach and the fuel gauge and the temp gauge were neither one work along with the info center and the PRNDL! I checked every fuse and every relay I could find including the ones under the dash beside the brake pedal which have nothing to do with what I am having trouble with as far as I have ever know. I have been a mechanic for a very very long time and have never seen this issue before and have checked all the grounds I could remember the location of. I have two other trucks of the same gen tried the cluster from both same issue. Tried the a/c control panel from both and again same issue! Solus says no codes and gave no help at all GRRRRR!!!! Any ideas guys? I really want my truck back to full working order and am stumped! Thanks for any help you can offer in advance!!!
