- Aug 26, 2013
- 6
My 96 Chevy K1500 has been having problems shifting from 1st to 2nd. It runs up high rpms until you let off gas before shift until tranny is warm, then it is better. Changed out to aluminum accumulator pistons, but have a question on the 1-2 position.
The older models have the piston into the housing first, then the spring. Mine in 96 came with the spring first, then the piston.
I've had mixed signals and the Transgo kit does it the old way (piston first then spring), but I'm not sure what to do!
Can anyone advise on this issue? Thanks!
