NEED HELP 07 trailblazer shut of and noww wont crank
Amorgan580
2
Homerville,ga
I have a 07 Chevy trailblazer I was driving the motor started shaking bad enough to shake the whole truck when I stopped it shut off it crank like two more times and was running super hard and rough now it will not start it will turn over but acts like it is not firing to start the motor
Wooluf1952
2,663
Milwaukee, Wisconsin
Welcome
In case you haven't heard:
https://gmtnation.com/forums/threads/welcome-to-gmtnation-com-heres-the-story.218/
Is the CEL light On? What's the maintenance history. Did you get gas lately?
Amorgan580
2
Homerville,ga
What is a cell light? And I just got it off a used lot 2 weeks ago the night it quit I had just got a little gas from a trusted store. Since it has stopped I have examined it has fuel pressure. When it is cranking nothing is pulling from the intake (airflow) according to my brother we tried starting it with either to see if gas flow was the problem it still didn't start just kept cranking like the gas wasn't being ignited my bro thinks there is something keeping it from firing my wife who was driving when it quit said it started running rough and the check engine light had started to blink also the check engine light was already on for an evap sensor
Wooluf1952
2,663
CEL=Check Engine Light. If the engine is cranking (turning over) with no suction at the intake, to me, that sounds like a timing chain problem.
Reactions: Wooluf1952
MissCrutcher
