06 Trailblazer with a persistent p0335 code
kawaholic
106
This problem started as a no start out of the blue one day last year. I'm going to copy and paste what I wrote on the other board that I didn't get any response to.
this is from 6/30/12
went into the store today. it was running fine. came out and hit the key. she fired up ran for MAYBE 2 seconds started running really rough and died. tried starting again and did the same thing. didn't have any tools with me so there wasn't a whole lot i could do. luckily a friend of mine was there to give me a ride home. planning on going back tomorrow with my manual and some tools to start trouble shooting. check engine light never came on. kinda seems like it's starving for fuel but it starts for those 1-2 seconds every time. never could really hear the fuel pump come on before starting it before this happened. tried switching the fuel pump relay with another relay but it didn't change anything. my first thought was something fuel related (maybe pressure regulator?) and my friend thinks it might be the crank sensor. he said he's had similar problems before and it turned out to be a bad crank sensor. any ideas? thanks in advance for any help or suggestions...
7/2/12
update:
i went back about 6hrs later and she fired up and ran like she normally does. drove it home no problem. get to the house shut it off and tried to start it again, nothing happens. now it just cranks, cranks, cranks... no more running for a few seconds and dying. now back at the house i can hear the fuel pump cycling on and off with the key. i also hear it when i stop cranking. it sounds like it's building pressure and cutting off like it should. still haven't checked fuel pressure but that's not the problem at this point in time.
the crank sensor was cheap enough that i went ahead and changed it. got a duralast from the zone. no change...checked for spark, had spark at first then it didn't. unplugged coil, tested for ignition voltage, got voltage, tested for ground, got ground, tested for signal from pcm, nothing. all fuses have been checked, rechecked and checked again. all good there.
according to my manual the only thing left is the pcm. just so happens that i have a pcm that i bought from pcm for less last year that i still hadn't installed due to the case relearn issue that i refused to pay the stealer over 100 bucks to do. now that i messed with the crank sensor i figured the case relearn is inevitable so i installed the new pcm. went through the security relearn process and it took after the third cycle of leaving the key on for 11 minutes and off for 30 seconds. STILL NO SPARK OR SIGNAL TO THE COILS!!!! WTF do i do now???? what's left? according to my manual i've covered everything that's involved in the ignition system. is there an ignition module somewhere that isn't mentioned in the manual? is there a way to test the crank sensor? the only thing the manual covers is replacing it. i'm at a loss as to what to do next. any ideas or suggestions would be MUCH appreciated.
tia, tom
7/4/12
still no love... tried doing the security relearn process a few more times after rereading the instructions that came with the pcm from pcm for less. even though the security relearn seemed to be completed (security light went out with the rest of the lights on the dash shortly after the key was switched to "run") on the third cycle of crank, leaving key on "run" for 11 minutes and "off" for 30 seconds, the instructions say to do the process for four times OR until the engine starts. it's not going to start b/c i've got it all apart but i'm testing for spark AND ignition signal to the coil and still have neither...
wiring schematics in my repair manual SUCK and don't really have any for the engine controls. i found some online that show the crank sensor with a purple and a yellow wire coming from the pcm. purple is the low reference and yellow is the crank signal back to the pcm. i've found some other low reference voltages for other sensors are 5 volts. never found a voltage called out for the crank sensor. i unplugged the crank sensor, checked for low voltage reference on the purple wire with the key on and got 2.4 volts. not sure if it should be higher or not but i am getting something. i'd like to plug the crank sensor back in and check for voltage coming back on the signal wire but i'm worried i might damage the pcm if i do. anyone have any thoughts on that?
anyone have a way to test the crank sensor off the vehicle? the manual doesn't give any info. i tried to test the resistance of the old one but not really sure what i'm looking for. iirc, i had my ohm meter set at 20k. when i test across the two pins on the sensor it reads 0.73 ohms. when i touch it to a piece of metal i see it drop some for a split second and go right back to 0.73. seems to me it should be reading 0.00 or at least drop to something lower and stay there while i have it on the metal but i don't know. i'm planning on pulling the new one back out and test it the same way to compare the two.
next plan is to find the yellow and purple wires where they come into the pcm and check them for continuity from the plug at the crank sensor to the plug at the pcm. if that all checks out i'm considering trying the original crank sensor or returning the new one for another one and/or bring both pcm's to the dealer and see if they can test them for me.
beyond that i don't know what else i can do. i guess no one else has had this problem or the folks with all the answers around here have taken an extended weekend to celebrate independence day.
i guess i should try calling pcm for less to see if they've ever run across something like this or maybe they can help get me pointed in the right direction. this truck has been pretty much problem free until now with 12x,xxx miles on her. never thought twice about driving it anywhere. now not so much, IF i can even get it running again...lol
9/8/13
back from the dead...lol... finally got the truck running last year but it still isn't right. wiring for ckp checked out from sensor to pcm. i finally decided to just put it all back together and it started. still not sure how it started... sometimes it starts first try, sometimes it takes a while but i've been able to get it started every time.
over the past year i've had a bunch of random codes pop up here and there, i have them all written down somewhere but i can't seem to find them right now. i've also had the reduced power light come on along with the traction control light. boy, the engine running in reduced power mode is FRIGHTENING...sounds like a bad running diesel engine. only way to get going again after the reduced power situation was to clear all codes with my scanner and she'd run fine again. that only happened a few times and it hasn't happened for a while now. knocking on wood.
check engine light comes and goes but one thing is always there whether the light is on or not. po335 crankshaft position sensor A circuit malfunction. right now it reads the same code three times. 1- history/current
2- confirmed and 3- pending.
these all came up yesterday, along with p0336 crankshaft position sensor A circuit range/performance. never saw this one before.
also got co327 encoder circuit (4 wheel drive seems to work fine) reads as history.
p0171 bank 1 system too lean, reads as intermittent. this is the first time i've seen these come up.
these came up a while back but i haven't seen them lately.
p2431
p0068 twice, one was pending
p0014
the really strange thing is if i don't go past half throttle it seems to run fine most of the time. if i try to put my foot into it, it'll fall on its face. usually when it falls on its face the tach drops to zero. sometimes it kicks the check engine light at this point but sometimes it doesn't. sometimes when it's acting up and won't start right away, the tach stays at zero when it finally starts. what's even stranger (if that's even possible at this point) is when the tach isn't working it runs like a raped ape!!!
since all this started over a year ago, i've replaced the crank sensor, pcm, had the case relearn done and the cam sensor. starter also went out a while back (most likely from all the excessive cranking) and that really seemed to improve the initial start ups but not the drivability issues i've been experiencing.
i've been starting to wonder if maybe the tach has something to do with all of this but i'm not so sure after reading all the threads about the stepper motors in the cluster. when the tach works, it's spot on with the scanner. if the tach drops out while the engine is running, the scanner stays at the last recorded rpm. if the tach reads zero on start up, the scanner reads zero also.
one thing i noticed in the data i recorded with the scanner yesterday was that the fuel injection system switched from closed loop to open loop a few different times WELL after the truck was warm. it's always been my understanding that it's only in open loop when it's cold at start up to richen the mixture.
sorry for the long winded post. i feel like i'm all over the place but i'm just trying to include all the info that i have. this thing has got me at my wits end. i really love this truck but i just feel like i can't depend on it anymore. any help would be much appreciated.
kawaholic
106
here's a copy of what the scanner spit out yesterday... frame 36 is when it really acted up and kicked the check engine light. at that time the tach dropped out and i had full power. hoping another set of eyes might catch something i'm missing. reading the numbers like this is kind of a pain in the ass. i can print a graph for each individual reading but i haven't figured a way to convert all the readings to a graph and print them after they're recorded.
2006 Chevrolet TrailBlazer 4WD S = 4.2
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon ok
Htd Catalyst n/a
Evap System Mon inc
Sec Air System ok
A/C Refrig Mon n/a
Oxygen Sens Mon ok
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
DTCs (Codes)
C0327 XFER $1A
Encoder Circuit
HISTORY
TOP REPORTED FIX
1-Replaced Transfer
Case
FREQ REPORTED FIXES
1-Replaced Transfer
Case Encoder Motor
2-Rebuilt Transfer
Case
3-Replaced Transfer
Case Control
Module (TCCM)
ALSO REPORTED FIXES
1-Replaced 4WD
Transfer Case
Shift Fork
2-Replaced Encoder
Motor Position
Sensor
3-Replaced Tire(s)
4-Repaired Transfer
Case
5-Tech Tip Transfer
Case
6-Replaced Transfer
Case Clutches
7-Repaired Transfer
Case Connector
8-Programmed
Transfer Case
Control Module
(TCCM)
9-Repaired Transfer
Case Control
Module (TCCM)
Wiring
10-Replaced Transfer
Case Encoder
Switch
11-Adjusted Transfer
Case Encoder
Switch
P0171 ENG $10
Bank 1 System Too Lean
CURRENT
TOP REPORTED FIX
1-Replaced Oxygen
(O2) Sensor(s)
FREQ REPORTED FIXES
1-Replaced Intake
Manifold Gasket(s)
2-Replaced Oxygen
(O2) Sensor, Bank
1 Sensor 1
3-Replaced
Evaporative
Emissions (EVAP)
Canister Purge
Solenoid/Valve
4-Replaced Catalytic
Converter(s)
5-Replaced Front
Oxygen (O2) Sensor
6-Cleaned Mass Air
Flow (MAF) Sensor
7-Connected Positive
Crankcase
Ventilation (PCV)
Breather Hose
8-Connected Breather
Hose
9-Replaced Fuel
10-Programmed
Powertrain Control
Module (PCM)
11-Replaced
Powertrain Control
Module (PCM)
12-Replaced Air
Injection Reaction
(AIR) Pump
13-Replaced Air
Injection Reaction
(AIR) Solenoid
14-Replaced Engine
Air Filter
15-Replaced Fuel Pump
16-Replaced Intake
Manifold
17-Replaced Mass Air
Flow (MAF) Sensor
ALSO REPORTED FIXES
1-Reset Adaptive
Fuel Memory
2-Replaced Air
Cleaner Element
3-Replaced Breather
Hose
4-Removed E-85 Fuel
5-Replaced Fuel
Filter
6-Replaced Fuel
Pressure Regulator
7-Cleaned Fuel
System
8-Replaced Gasoline
9-Replaced Heated
Oxygen Sensor
(HO2S)
10-Replaced Intake
Manifold Plenum
Gaskets
11-Replaced Manifold
Absolute Pressure
(MAP) Sensor
12-Replaced Mass Air
Flow (MAF) Sensor
O-Ring
13-Replaced Oxygen
(O2) Sensor, Bank
1 Sensor 2
14-Replaced PCV Hose
15-Repaired PCV Hose
16-Connected PCV Hose
17-Replaced Positive
Crankcase
Ventilation (PCV)
Breather Hose
18-Replaced Spark
Plug(s)
19-Cleaned Throttle
Body
20-Connected Vacuum
Hose/Line(s)
21-Installed Vacuum
Hose/Line(s)
P0335 ENG $10
Crankshaft Position Sensor A Circuit
Malfunction
CURRENT HISTORY MIL
FREQ REPORTED FIX
1-Replaced Camshaft
Position (CMP)
Sensor
ALSO REPORTED FIXES
1-Replaced Catalytic
Converter(s)
2-Replaced Fuel
Pressure Regulator
3-Programmed
Powertrain Control
Module (PCM)
4-Repaired
Powertrain Control
Module (PCM)
Wiring
P0336 ENG $10
Range / Performance
INTERMITTENT
FREQ REPORTED FIXES
Converter(s)
2-Replaced
Crankshaft
Position (CKP)
Sensor
3-Replaced Fuel
Pressure Regulator
P0335 MOD $10
Malfunction
CONFIRMED
FREQ REPORTED FIX
1-Replaced Camshaft
Position (CMP)
Sensor
ALSO REPORTED FIXES
Converter(s)
2-Replaced Fuel
Pressure Regulator
3-Programmed
Powertrain Control
Module (PCM)
4-Repaired
Powertrain Control
Module (PCM)
Wiring
P0171 MOD $10
PENDING
TOP REPORTED FIX
1-Replaced Oxygen
(O2) Sensor(s)
FREQ REPORTED FIXES
1-Replaced Intake
Manifold Gasket(s)
2-Replaced Oxygen
(O2) Sensor, Bank
1 Sensor 1
3-Replaced
Evaporative
Emissions (EVAP)
Canister Purge
Solenoid/Valve
Converter(s)
5-Replaced Front
Oxygen (O2) Sensor
6-Cleaned Mass Air
Flow (MAF) Sensor
Crankcase
Ventilation (PCV)
Breather Hose
Hose
9-Replaced Fuel
10-Programmed
Powertrain Control
Module (PCM)
11-Replaced
Powertrain Control
Module (PCM)
12-Replaced Air
Injection Reaction
(AIR) Pump
13-Replaced Air
Injection Reaction
(AIR) Solenoid
14-Replaced Engine
Air Filter
16-Replaced Intake
Manifold
Flow (MAF) Sensor
ALSO REPORTED FIXES
1-Reset Adaptive
Fuel Memory
2-Replaced Air
Cleaner Element
3-Replaced Breather
Hose
4-Removed E-85 Fuel
5-Replaced Fuel
Filter
6-Replaced Fuel
Pressure Regulator
7-Cleaned Fuel
System
8-Replaced Gasoline
9-Replaced Heated
Oxygen Sensor
(HO2S)
10-Replaced Intake
Manifold Plenum
Gaskets
Absolute Pressure
(MAP) Sensor
Flow (MAF) Sensor
O-Ring
13-Replaced Oxygen
(O2) Sensor, Bank
1 Sensor 2
Crankcase
Ventilation (PCV)
Breather Hose
18-Replaced Spark
Plug(s)
19-Cleaned Throttle
Body
20-Connected Vacuum
Hose/Line(s)
21-Installed Vacuum
Hose/Line(s)
P0335 MOD $10
Malfunction
PENDING
FREQ REPORTED FIX
1-Replaced Camshaft
Position (CMP)
Sensor
ALSO REPORTED FIXES
Converter(s)
2-Replaced Fuel
Pressure Regulator
3-Programmed
Powertrain Control
Module (PCM)
4-Repaired
Powertrain Control
Module (PCM)
Wiring
P0336 MOD $10
Range / Performance
PENDING
FREQ REPORTED FIXES
Converter(s)
2-Replaced
Crankshaft
Position (CKP)
Sensor
3-Replaced Fuel
Pressure Regulator
Record Data
FRAME: -2 TM: -4.4
MIL STATUS Off
ABSLT TPS(%) 32.9
ENG SPEED(RPM) 1791
CALC LOAD(%) 73.3
MAF(LB/M) 4.31
MAP("HG) 19.5
COOLANT(°F) 196
IAT(°F) 88
IGN ADV(°) 26.0
SECOND AIR ATMOS
ST FTRM1(%) -2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 47
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.150
ST FTRM11(%) -2.3
O2S12(V) 0.755
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: -1 TM: -2.3
MIL STATUS Off
ABSLT TPS(%) 32.6
ENG SPEED(RPM) 1763
CALC LOAD(%) 70.2
MAF(LB/M) 4.19
MAP("HG) 18.6
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 26.0
SECOND AIR ATMOS
ST FTRM1(%) 3.1
LT FTRM1(%) -3.1
VEH SPEED(MPH) 48
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.710
ST FTRM11(%) 2.3
O2S12(V) 0.740
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 31.8
ENG SPEED(RPM) 1660
CALC LOAD(%) 67.5
MAF(LB/M) 3.80
MAP("HG) 18.3
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 26.5
SECOND AIR ATMOS
ST FTRM1(%) -2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 49
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.240
ST FTRM11(%) -1.6
O2S12(V) 0.750
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 1 TM: 2.1
MIL STATUS Off
ABSLT TPS(%) 31.4
ENG SPEED(RPM) 1621
CALC LOAD(%) 63.5
MAF(LB/M) 3.43
MAP("HG) 17.4
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 31.0
SECOND AIR ATMOS
ST FTRM1(%) 7.0
LT FTRM1(%) -5.5
VEH SPEED(MPH) 51
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.710
ST FTRM11(%) 4.7
O2S12(V) 0.745
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 2 TM: 4.2
MIL STATUS Off
ABSLT TPS(%) 29.4
ENG SPEED(RPM) 1561
CALC LOAD(%) 52.9
MAF(LB/M) 2.70
MAP("HG) 15.7
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 30.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -5.5
VEH SPEED(MPH) 52
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.095
ST FTRM11(%) 5.5
O2S12(V) 0.745
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 3 TM: 6.3
MIL STATUS Off
ABSLT TPS(%) 29.4
ENG SPEED(RPM) 1412
CALC LOAD(%) 55.7
MAF(LB/M) 2.61
MAP("HG) 15.9
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 31.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -4.7
VEH SPEED(MPH) 52
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.455
ST FTRM11(%) 1.6
O2S12(V) 0.745
MIL DIST(mi) 9
OBD2 STAT CA/US
continued in next post
kawaholic
106
FRAME: 4 TM: 8.4
MIL STATUS Off
ABSLT TPS(%) 29.4
ENG SPEED(RPM) 1440
CALC LOAD(%) 54.1
MAF(LB/M) 2.61
MAP("HG) 15.7
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 32.5
SECOND AIR ATMOS
ST FTRM1(%) 3.1
LT FTRM1(%) -4.7
VEH SPEED(MPH) 53
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.690
ST FTRM11(%) 8.6
O2S12(V) 0.745
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 5 TM: 10.5
MIL STATUS Off
ABSLT TPS(%) 29.4
ENG SPEED(RPM) 1472
CALC LOAD(%) 53.7
MAF(LB/M) 2.64
MAP("HG) 14.8
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 32.5
SECOND AIR ATMOS
ST FTRM1(%) 8.6
LT FTRM1(%) -3.9
VEH SPEED(MPH) 55
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.060
ST FTRM11(%) 4.7
O2S12(V) 0.800
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 6 TM: 12.5
MIL STATUS Off
ABSLT TPS(%) 59.2
ENG SPEED(RPM) 2735
CALC LOAD(%) 100.0
MAF(LB/M) 12.78
MAP("HG) 29.2
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 15.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 60
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.885
ST FTRM11(%) 0.0
O2S12(V) 0.910
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 7 TM: 14.6
MIL STATUS Off
ABSLT TPS(%) 87.5
ENG SPEED(RPM) 4195
CALC LOAD(%) 100.0
MAF(LB/M) 21.24
MAP("HG) 29.2
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 20.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 66
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.915
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 8 TM: 16.6
MIL STATUS Off
ABSLT TPS(%) 73.3
ENG SPEED(RPM) 4753
CALC LOAD(%) 100.0
MAF(LB/M) 25.60
MAP("HG) 28.9
COOLANT(°F) 196
IAT(°F) 84
IGN ADV(°) 18.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 76
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.770
ST FTRM11(%) -7.0
O2S12(V) 0.895
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 9 TM: 18.7
MIL STATUS Off
ABSLT TPS(%) 24.3
ENG SPEED(RPM) 2784
CALC LOAD(%) 20.0
MAF(LB/M) 2.02
MAP("HG) 5.9
COOLANT(°F) 196
IAT(°F) 86
IGN ADV(°) 26.5
SECOND AIR ATMOS
ST FTRM1(%) -0.8
LT FTRM1(%) -4.7
VEH SPEED(MPH) 76
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.800
ST FTRM11(%) -0.8
O2S12(V) 0.855
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 10 TM: 20.8
MIL STATUS Off
ABSLT TPS(%) 21.2
ENG SPEED(RPM) 1935
CALC LOAD(%) 22.7
MAF(LB/M) 1.48
MAP("HG) 6.8
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) 0.8
LT FTRM1(%) -4.7
VEH SPEED(MPH) 70
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.095
ST FTRM11(%) 1.6
O2S12(V) 0.840
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 11 TM: 22.9
MIL STATUS Off
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 1538
CALC LOAD(%) 27.5
MAF(LB/M) 1.35
MAP("HG) 7.7
COOLANT(°F) 198
IAT(°F) 88
IGN ADV(°) 3.0
SECOND AIR ATMOS
ST FTRM1(%) 6.3
LT FTRM1(%) -4.7
VEH SPEED(MPH) 63
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.510
ST FTRM11(%) -1.6
O2S12(V) 0.105
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 12 TM: 25.0
MIL STATUS Off
ABSLT TPS(%) 21.2
ENG SPEED(RPM) 1504
CALC LOAD(%) 31.0
MAF(LB/M) 1.59
MAP("HG) 8.3
COOLANT(°F) 199
IAT(°F) 88
IGN ADV(°) 24.0
SECOND AIR ATMOS
ST FTRM1(%) -1.6
LT FTRM1(%) -3.9
VEH SPEED(MPH) 60
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.705
ST FTRM11(%) -3.9
O2S12(V) 0.240
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 13 TM: 27.3
MIL STATUS Off
ABSLT TPS(%) 38.4
ENG SPEED(RPM) 2178
CALC LOAD(%) 100.0
MAF(LB/M) 8.15
MAP("HG) 26.0
COOLANT(°F) 199
IAT(°F) 88
IGN ADV(°) 17.0
SECOND AIR ATMOS
ST FTRM1(%) 6.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 61
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.745
ST FTRM11(%) -1.6
O2S12(V) 0.685
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 14 TM: 29.3
MIL STATUS Off
ABSLT TPS(%) 63.5
ENG SPEED(RPM) 4223
CALC LOAD(%) 100.0
MAF(LB/M) 20.69
MAP("HG) 28.6
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 65
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.915
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 15 TM: 31.4
MIL STATUS Off
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 4596
CALC LOAD(%) 100.0
MAF(LB/M) 24.24
MAP("HG) 28.9
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 15.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 71
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.910
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 16 TM: 33.6
MIL STATUS Off
ABSLT TPS(%) 67.5
ENG SPEED(RPM) 4981
CALC LOAD(%) 100.0
MAF(LB/M) 26.32
MAP("HG) 28.3
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 19.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 78
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.890
ST FTRM11(%) -4.7
O2S12(V) 0.905
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 17 TM: 35.6
MIL STATUS Off
ABSLT TPS(%) 24.7
ENG SPEED(RPM) 2983
CALC LOAD(%) 18.0
MAF(LB/M) 1.98
MAP("HG) 5.9
COOLANT(°F) 198
IAT(°F) 86
IGN ADV(°) 23.5
SECOND AIR ATMOS
ST FTRM1(%) -14.8
LT FTRM1(%) -4.7
VEH SPEED(MPH) 76
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.090
ST FTRM11(%) -7.8
O2S12(V) 0.870
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 18 TM: 37.7
MIL STATUS Off
ABSLT TPS(%) 20.8
ENG SPEED(RPM) 1929
CALC LOAD(%) 22.7
MAF(LB/M) 1.52
MAP("HG) 6.5
COOLANT(°F) 199
IAT(°F) 88
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) -3.1
LT FTRM1(%) -4.7
VEH SPEED(MPH) 71
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.140
ST FTRM11(%) -1.6
O2S12(V) 0.840
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 19 TM: 39.8
MIL STATUS Off
ABSLT TPS(%) 21.6
ENG SPEED(RPM) 1751
CALC LOAD(%) 27.1
MAF(LB/M) 1.75
MAP("HG) 8.9
COOLANT(°F) 199
IAT(°F) 88
IGN ADV(°) 37.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 66
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.225
ST FTRM11(%) -4.7
O2S12(V) 0.815
MIL DIST(mi) 9
OBD2 STAT CA/US
kawaholic
106
FRAME: 20 TM: 41.8
MIL STATUS Off
ABSLT TPS(%) 26.7
ENG SPEED(RPM) 1799
CALC LOAD(%) 37.7
MAF(LB/M) 2.24
MAP("HG) 10.0
COOLANT(°F) 201
IAT(°F) 88
IGN ADV(°) 37.0
SECOND AIR ATMOS
ST FTRM1(%) -6.3
LT FTRM1(%) -3.9
VEH SPEED(MPH) 63
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.190
ST FTRM11(%) -0.8
O2S12(V) 0.805
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 21 TM: 43.9
MIL STATUS Off
ABSLT TPS(%) 27.1
ENG SPEED(RPM) 1741
CALC LOAD(%) 40.0
MAF(LB/M) 2.67
MAP("HG) 12.1
COOLANT(°F) 201
IAT(°F) 88
IGN ADV(°) 15.0
SECOND AIR ATMOS
ST FTRM1(%) -5.5
LT FTRM1(%) -3.1
VEH SPEED(MPH) 61
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.875
ST FTRM11(%) 0.0
O2S12(V) 0.880
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 22 TM: 46.0
MIL STATUS Off
ABSLT TPS(%) 58.0
ENG SPEED(RPM) 4139
CALC LOAD(%) 100.0
MAF(LB/M) 20.16
MAP("HG) 28.3
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 18.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 63
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.875
ST FTRM11(%) 0.0
O2S12(V) 0.895
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 23 TM: 48.1
MIL STATUS Off
ABSLT TPS(%) 50.2
ENG SPEED(RPM) 2861
CALC LOAD(%) 47.8
MAF(LB/M) 3.14
MAP("HG) 9.4
COOLANT(°F) 199
IAT(°F) 86
IGN ADV(°) 29.5
SECOND AIR ATMOS
ST FTRM1(%) -0.8
LT FTRM1(%) -4.7
VEH SPEED(MPH) 63
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.820
ST FTRM11(%) -10.9
O2S12(V) 0.880
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 24 TM: 50.2
MIL STATUS Off
ABSLT TPS(%) 21.2
ENG SPEED(RPM) 1495
CALC LOAD(%) 31.4
MAF(LB/M) 1.53
MAP("HG) 8.3
COOLANT(°F) 199
IAT(°F) 86
IGN ADV(°) 7.5
SECOND AIR ATMOS
ST FTRM1(%) -0.8
LT FTRM1(%) -5.5
VEH SPEED(MPH) 59
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.110
ST FTRM11(%) 0.8
O2S12(V) 0.850
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 25 TM: 52.3
MIL STATUS Off
ABSLT TPS(%) 36.1
ENG SPEED(RPM) 2070
CALC LOAD(%) 96.5
MAF(LB/M) 6.51
MAP("HG) 23.0
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 24.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 57
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.745
ST FTRM11(%) -7.0
O2S12(V) 0.795
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 26 TM: 54.5
MIL STATUS Off
ABSLT TPS(%) 32.9
ENG SPEED(RPM) 1917
CALC LOAD(%) 70.6
MAF(LB/M) 4.08
MAP("HG) 17.7
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 38.5
SECOND AIR ATMOS
ST FTRM1(%) -10.9
LT FTRM1(%) -5.5
VEH SPEED(MPH) 57
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.695
ST FTRM11(%) -6.3
O2S12(V) 0.790
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 27 TM: 56.6
MIL STATUS Off
ABSLT TPS(%) 22.0
ENG SPEED(RPM) 1564
CALC LOAD(%) 31.4
MAF(LB/M) 1.75
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 35.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -4.7
VEH SPEED(MPH) 55
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.210
ST FTRM11(%) -1.6
O2S12(V) 0.785
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 28 TM: 58.6
MIL STATUS Off
ABSLT TPS(%) 28.2
ENG SPEED(RPM) 1613
CALC LOAD(%) 48.2
MAF(LB/M) 2.53
MAP("HG) 13.6
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 38.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -4.7
VEH SPEED(MPH) 53
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.125
ST FTRM11(%) -3.9
O2S12(V) 0.775
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 29 TM: 60.7
MIL STATUS Off
ABSLT TPS(%) 31.8
ENG SPEED(RPM) 1689
CALC LOAD(%) 68.6
MAF(LB/M) 4.19
MAP("HG) 20.1
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -3.9
VEH SPEED(MPH) 53
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.430
ST FTRM11(%) 4.7
O2S12(V) 0.745
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 30 TM: 62.7
MIL STATUS Off
ABSLT TPS(%) 59.2
ENG SPEED(RPM) 2688
CALC LOAD(%) 100.0
MAF(LB/M) 12.43
MAP("HG) 29.2
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 15.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 55
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.900
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 31 TM: 64.8
MIL STATUS Off
ABSLT TPS(%) 72.6
ENG SPEED(RPM) 4007
CALC LOAD(%) 100.0
MAF(LB/M) 20.16
MAP("HG) 29.2
COOLANT(°F) 201
IAT(°F) 84
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 62
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.880
ST FTRM11(%) 0.0
O2S12(V) 0.905
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 32 TM: 66.9
MIL STATUS Off
ABSLT TPS(%) 70.6
ENG SPEED(RPM) 4371
CALC LOAD(%) 100.0
MAF(LB/M) 21.79
MAP("HG) 28.9
COOLANT(°F) 199
IAT(°F) 86
IGN ADV(°) 20.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 68
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.875
ST FTRM11(%) 0.0
O2S12(V) 0.895
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 33 TM: 68.9
MIL STATUS Off
ABSLT TPS(%) 68.6
ENG SPEED(RPM) 4647
CALC LOAD(%) 100.0
MAF(LB/M) 24.89
MAP("HG) 28.9
COOLANT(°F) 199
IAT(°F) 86
IGN ADV(°) 15.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 73
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.865
ST FTRM11(%) 0.0
O2S12(V) 0.880
MIL DIST(mi) 9
OBD2 STAT CA/US
FRAME: 34 TM: 71.0
MIL STATUS Off
ABSLT TPS(%) 69.0
ENG SPEED(RPM) 5020
CALC LOAD(%) 100.0
MAF(LB/M) 26.32
MAP("HG) 28.6
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 14.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 78
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.850
ST FTRM11(%) 0.0
O2S12(V) 0.875
MIL DIST(mi) 9
OBD2 STAT CA/US
kawaholic
106
check engine light is getting ready to come on soon...
FRAME: 35 TM: 73.1
MIL STATUS Off
ABSLT TPS(%) 63.1
ENG SPEED(RPM) 5082
CALC LOAD(%) 100.0
MAF(LB/M) 27.84
MAP("HG) 8.3
COOLANT(°F) 201
IAT(°F) 86
IGN ADV(°) 12.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 82
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
O2S11(V) 0.865
ST FTRM11(%) 0.0
O2S12(V) 0.900
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 36 TM: 75.1
MIL STATUS On
ABSLT TPS(%) 31.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 18.4
MAF(LB/M) 2.29
MAP("HG) 6.5
COOLANT(°F) 203
IAT(°F) 86
IGN ADV(°) 23.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -5.5
VEH SPEED(MPH) 81
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
O2S11(V) 0.840
ST FTRM11(%) 0.0
O2S12(V) 0.880
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 37 TM: 77.3
MIL STATUS On
ABSLT TPS(%) 23.5
ENG SPEED(RPM) 5342
CALC LOAD(%) 25.1
MAF(LB/M) 1.87
MAP("HG) 8.0
COOLANT(°F) 203
IAT(°F) 88
IGN ADV(°) 23.0
SECOND AIR ATMOS
ST FTRM1(%) -3.1
LT FTRM1(%) -5.5
VEH SPEED(MPH) 73
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.125
ST FTRM11(%) 1.6
O2S12(V) 0.850
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 38 TM: 79.3
MIL STATUS On
ABSLT TPS(%) 23.1
ENG SPEED(RPM) 5342
CALC LOAD(%) 28.6
MAF(LB/M) 1.80
MAP("HG) 8.3
COOLANT(°F) 205
IAT(°F) 88
IGN ADV(°) 20.0
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -5.5
VEH SPEED(MPH) 68
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.700
ST FTRM11(%) -3.9
O2S12(V) 0.820
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 39 TM: 81.9
MIL STATUS On
ABSLT TPS(%) 21.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 26.7
MAF(LB/M) 1.60
MAP("HG) 8.0
COOLANT(°F) 207
IAT(°F) 88
IGN ADV(°) 17.5
SECOND AIR ATMOS
ST FTRM1(%) 2.3
LT FTRM1(%) -5.5
VEH SPEED(MPH) 66
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.105
ST FTRM11(%) 3.1
O2S12(V) 0.805
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 40 TM: 84.0
MIL STATUS On
ABSLT TPS(%) 21.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 26.7
MAF(LB/M) 1.55
MAP("HG) 8.0
COOLANT(°F) 207
IAT(°F) 88
IGN ADV(°) 16.0
SECOND AIR ATMOS
ST FTRM1(%) 3.1
LT FTRM1(%) -4.7
VEH SPEED(MPH) 66
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.770
ST FTRM11(%) -4.7
O2S12(V) 0.795
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 41 TM: 86.2
MIL STATUS On
ABSLT TPS(%) 29.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 40.8
MAF(LB/M) 2.16
MAP("HG) 8.9
COOLANT(°F) 207
IAT(°F) 88
IGN ADV(°) 24.0
SECOND AIR ATMOS
ST FTRM1(%) 4.7
LT FTRM1(%) -5.5
VEH SPEED(MPH) 68
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.100
ST FTRM11(%) -1.6
O2S12(V) 0.790
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 42 TM: 88.4
MIL STATUS On
ABSLT TPS(%) 21.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 27.1
MAF(LB/M) 1.56
MAP("HG) 8.0
COOLANT(°F) 205
IAT(°F) 88
IGN ADV(°) 18.5
SECOND AIR ATMOS
ST FTRM1(%) -1.6
LT FTRM1(%) -5.5
VEH SPEED(MPH) 68
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.645
ST FTRM11(%) 3.9
O2S12(V) 0.785
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 43 TM: 91.0
MIL STATUS On
ABSLT TPS(%) 21.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 26.7
MAF(LB/M) 1.59
MAP("HG) 8.0
COOLANT(°F) 205
IAT(°F) 88
IGN ADV(°) 17.5
SECOND AIR ATMOS
ST FTRM1(%) 4.7
LT FTRM1(%) -5.5
VEH SPEED(MPH) 66
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.105
ST FTRM11(%) 4.7
O2S12(V) 0.785
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 44 TM: 93.1
MIL STATUS On
ABSLT TPS(%) 20.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 23.5
MAF(LB/M) 1.38
MAP("HG) 7.4
COOLANT(°F) 205
IAT(°F) 86
IGN ADV(°) 14.0
SECOND AIR ATMOS
ST FTRM1(%) 5.5
LT FTRM1(%) -5.5
VEH SPEED(MPH) 62
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.615
ST FTRM11(%) 4.7
O2S12(V) 0.785
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 45 TM: 95.2
MIL STATUS On
ABSLT TPS(%) 36.5
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 10.05
MAP("HG) 29.2
COOLANT(°F) 205
IAT(°F) 86
IGN ADV(°) 5.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 63
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.875
ST FTRM11(%) 0.0
O2S12(V) 0.895
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 46 TM: 97.3
MIL STATUS On
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 21.24
MAP("HG) 29.2
COOLANT(°F) 203
IAT(°F) 86
IGN ADV(°) 10.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 68
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.880
ST FTRM11(%) 0.0
O2S12(V) 0.895
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 47 TM: 99.4
MIL STATUS On
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 22.97
MAP("HG) 28.9
COOLANT(°F) 203
IAT(°F) 84
IGN ADV(°) 9.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 73
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.875
ST FTRM11(%) 0.0
O2S12(V) 0.885
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 48 TM: 101.4
MIL STATUS On
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 24.24
MAP("HG) 29.2
COOLANT(°F) 203
IAT(°F) 86
IGN ADV(°) 9.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 77
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.865
ST FTRM11(%) 0.0
O2S12(V) 0.885
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 49 TM: 103.5
MIL STATUS On
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 25.60
MAP("HG) 29.2
COOLANT(°F) 203
IAT(°F) 86
IGN ADV(°) 6.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 81
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.865
ST FTRM11(%) 0.0
O2S12(V) 0.885
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 50 TM: 105.5
MIL STATUS On
ABSLT TPS(%) 88.2
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 26.32
MAP("HG) 28.9
COOLANT(°F) 203
IAT(°F) 84
IGN ADV(°) 7.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 83
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.855
ST FTRM11(%) 0.0
O2S12(V) 0.885
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 51 TM: 107.6
MIL STATUS On
ABSLT TPS(%) 77.3
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 26.32
MAP("HG) 29.2
COOLANT(°F) 205
IAT(°F) 84
IGN ADV(°) 9.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 84
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.855
ST FTRM11(%) 0.0
O2S12(V) 0.880
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 52 TM: 109.7
MIL STATUS On
ABSLT TPS(%) 51.0
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 15.80
MAP("HG) 28.3
COOLANT(°F) 205
IAT(°F) 84
IGN ADV(°) 11.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 84
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.815
ST FTRM11(%) -7.0
O2S12(V) 0.845
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 53 TM: 111.8
MIL STATUS On
ABSLT TPS(%) 22.7
ENG SPEED(RPM) 5342
CALC LOAD(%) 22.0
MAF(LB/M) 1.72
MAP("HG) 7.4
COOLANT(°F) 207
IAT(°F) 86
IGN ADV(°) 24.5
SECOND AIR ATMOS
ST FTRM1(%) -5.5
LT FTRM1(%) -5.5
VEH SPEED(MPH) 78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.130
ST FTRM11(%) -10.9
O2S12(V) 0.830
MIL DIST(mi) 1
OBD2 STAT CA/US
kawaholic
106
FRAME: 54 TM: 113.8
MIL STATUS On
ABSLT TPS(%) 20.8
ENG SPEED(RPM) 5342
CALC LOAD(%) 23.1
MAF(LB/M) 1.48
MAP("HG) 7.1
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) -5.5
LT FTRM1(%) -6.3
VEH SPEED(MPH) 68
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.170
ST FTRM11(%) -10.9
O2S12(V) 0.810
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 55 TM: 115.9
MIL STATUS On
ABSLT TPS(%) 20.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 23.9
MAF(LB/M) 1.39
MAP("HG) 7.4
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 4.0
SECOND AIR ATMOS
ST FTRM1(%) -4.7
LT FTRM1(%) -5.5
VEH SPEED(MPH) 62
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.000
ST FTRM11(%) 2.3
O2S12(V) 0.795
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 56 TM: 118.1
MIL STATUS On
ABSLT TPS(%) 22.0
ENG SPEED(RPM) 5342
CALC LOAD(%) 28.6
MAF(LB/M) 1.63
MAP("HG) 8.6
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -7.0
VEH SPEED(MPH) 58
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.140
ST FTRM11(%) -3.9
O2S12(V) 0.780
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 57 TM: 120.2
MIL STATUS On
ABSLT TPS(%) 28.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 51.4
MAF(LB/M) 2.73
MAP("HG) 13.0
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 26.5
SECOND AIR ATMOS
ST FTRM1(%) -7.8
LT FTRM1(%) -4.7
VEH SPEED(MPH) 56
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.425
ST FTRM11(%) -7.0
O2S12(V) 0.755
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 58 TM: 122.2
MIL STATUS On
ABSLT TPS(%) 32.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 75.7
MAF(LB/M) 5.63
MAP("HG) 21.9
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 10.5
SECOND AIR ATMOS
ST FTRM1(%) -3.9
LT FTRM1(%) -3.9
VEH SPEED(MPH) 56
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.185
ST FTRM11(%) -4.7
O2S12(V) 0.740
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 59 TM: 124.4
MIL STATUS On
ABSLT TPS(%) 33.7
ENG SPEED(RPM) 5342
CALC LOAD(%) 93.3
MAF(LB/M) 4.77
MAP("HG) 21.6
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 2.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
LT FTRM1(%) -3.9
VEH SPEED(MPH) 57
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.700
ST FTRM11(%) 1.6
O2S12(V) 0.725
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 60 TM: 126.5
MIL STATUS On
ABSLT TPS(%) 33.3
ENG SPEED(RPM) 5342
CALC LOAD(%) 86.7
MAF(LB/M) 4.56
MAP("HG) 20.4
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 3.0
SECOND AIR ATMOS
ST FTRM1(%) -2.3
LT FTRM1(%) -3.9
VEH SPEED(MPH) 58
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.105
ST FTRM11(%) 0.0
O2S12(V) 0.725
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 61 TM: 128.5
MIL STATUS On
ABSLT TPS(%) 62.8
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 18.24
MAP("HG) 28.6
COOLANT(°F) 208
IAT(°F) 84
IGN ADV(°) 11.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 60
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.870
ST FTRM11(%) 0.0
O2S12(V) 0.895
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 62 TM: 130.7
MIL STATUS On
ABSLT TPS(%) 56.9
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 18.71
MAP("HG) 28.6
COOLANT(°F) 208
IAT(°F) 84
IGN ADV(°) 10.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 65
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.865
ST FTRM11(%) 0.0
O2S12(V) 0.890
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 63 TM: 132.7
MIL STATUS On
ABSLT TPS(%) 47.1
ENG SPEED(RPM) 5342
CALC LOAD(%) 100.0
MAF(LB/M) 13.14
MAP("HG) 28.1
COOLANT(°F) 208
IAT(°F) 84
IGN ADV(°) 5.5
SECOND AIR ATMOS
ST FTRM1(%) -11.7
LT FTRM1(%) -4.7
VEH SPEED(MPH) 66
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11(V) 0.050
ST FTRM11(%) -5.5
O2S12(V) 0.800
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 64 TM: 134.8
MIL STATUS On
ABSLT TPS(%) 20.0
ENG SPEED(RPM) 5342
CALC LOAD(%) 23.5
MAF(LB/M) 1.40
MAP("HG) 7.4
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 16.5
SECOND AIR ATMOS
ST FTRM1(%) -3.1
LT FTRM1(%) -7.0
VEH SPEED(MPH) 64
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.320
ST FTRM11(%) -7.8
O2S12(V) 0.795
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 65 TM: 136.9
MIL STATUS On
ABSLT TPS(%) 20.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 23.9
MAF(LB/M) 1.36
MAP("HG) 7.4
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 14.0
SECOND AIR ATMOS
ST FTRM1(%) -1.6
LT FTRM1(%) -7.0
VEH SPEED(MPH) 63
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.665
ST FTRM11(%) -7.0
O2S12(V) 0.785
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 66 TM: 139.1
MIL STATUS On
ABSLT TPS(%) 29.8
ENG SPEED(RPM) 5342
CALC LOAD(%) 44.3
MAF(LB/M) 2.73
MAP("HG) 12.1
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 31.0
SECOND AIR ATMOS
ST FTRM1(%) 0.8
LT FTRM1(%) -5.5
VEH SPEED(MPH) 62
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.140
ST FTRM11(%) 0.8
O2S12(V) 0.770
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 67 TM: 141.1
MIL STATUS On
ABSLT TPS(%) 30.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 54.5
MAF(LB/M) 3.07
MAP("HG) 13.9
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 23.5
SECOND AIR ATMOS
ST FTRM1(%) -3.9
LT FTRM1(%) -5.5
VEH SPEED(MPH) 61
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.150
ST FTRM11(%) -3.1
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 68 TM: 143.2
MIL STATUS On
ABSLT TPS(%) 22.4
ENG SPEED(RPM) 5342
CALC LOAD(%) 31.0
MAF(LB/M) 1.69
MAP("HG) 8.9
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 10.5
SECOND AIR ATMOS
ST FTRM1(%) -1.6
LT FTRM1(%) -7.0
VEH SPEED(MPH) 60
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.405
ST FTRM11(%) -1.6
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
kawaholic
106
FRAME: 69 TM: 145.3
MIL STATUS On
ABSLT TPS(%) 20.8
ENG SPEED(RPM) 5342
CALC LOAD(%) 28.6
MAF(LB/M) 1.45
MAP("HG) 8.6
COOLANT(°F) 210
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) -1.6
LT FTRM1(%) -7.0
VEH SPEED(MPH) 58
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.715
ST FTRM11(%) -2.3
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 70 TM: 147.5
MIL STATUS On
ABSLT TPS(%) 20.8
ENG SPEED(RPM) 5342
CALC LOAD(%) 29.4
MAF(LB/M) 1.40
MAP("HG) 8.6
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) -2.3
LT FTRM1(%) -7.0
VEH SPEED(MPH) 50
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.730
ST FTRM11(%) -2.3
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 71 TM: 149.6
MIL STATUS On
ABSLT TPS(%) 20.0
ENG SPEED(RPM) 5342
CALC LOAD(%) 33.3
MAF(LB/M) 1.33
MAP("HG) 9.4
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) -3.9
LT FTRM1(%) -7.0
VEH SPEED(MPH) 37
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.695
ST FTRM11(%) -3.9
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 72 TM: 151.6
MIL STATUS On
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 40.0
MAF(LB/M) 1.25
MAP("HG) 11.2
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) 0.8
LT FTRM1(%) -7.0
VEH SPEED(MPH) 24
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.185
ST FTRM11(%) 0.0
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 73 TM: 153.7
MIL STATUS On
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 5342
CALC LOAD(%) 41.6
MAF(LB/M) 1.27
MAP("HG) 11.5
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) 8.0
SECOND AIR ATMOS
ST FTRM1(%) -5.5
LT FTRM1(%) -7.0
VEH SPEED(MPH) 14
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.080
ST FTRM11(%) 0.8
O2S12(V) 0.760
MIL DIST(mi) 1
OBD2 STAT CA/US
FRAME: 74 TM: 155.8
MIL STATUS On
ABSLT TPS(%) 18.0
ENG SPEED(RPM) 5342
CALC LOAD(%) 38.0
MAF(LB/M) 1.03
MAP("HG) 10.9
COOLANT(°F) 208
IAT(°F) 86
IGN ADV(°) -2.5
SECOND AIR ATMOS
ST FTRM1(%) 7.0
LT FTRM1(%) -7.0
VEH SPEED(MPH) 7
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11(V) 0.100
ST FTRM11(%) 8.6
O2S12(V) 0.765
MIL DIST(mi) 1
OBD2 STAT CA/US
O2 Monitor Tests
Vehicle did not return data for any O2
monitor tests
Diag Monitor Tests
Test $03
ID 01
MOD $10
MAX 00
MEAS 2854
MIN ----
STS HI
Test $05
ID 01
MOD $10
MAX FFFF
MEAS 3860
MIN ----
STS OK
ID 02
MOD $10
MAX FFFF
MEAS 3860
MIN ----
STS OK
ID 03
MOD $10
MAX FFFF
MEAS 2BC0
MIN ----
STS OK
ID 04
MOD $10
MAX FFFF
MEAS 5140
MIN ----
STS OK
ID 05
MOD $10
MAX 3273
MEAS DC8
MIN ----
STS OK
ID 06
MOD $10
MAX 3273
MEAS C4E
MIN ----
STS OK
ID 07
MOD $10
MAX ----
MEAS 13D
MIN 6E
STS OK
ID 08
MOD $10
MAX ----
MEAS 140
MIN 6E
STS OK
ID 0C
MOD $10
MAX 1F40
MEAS 1368
MIN ----
STS OK
ID 0B
MOD $10
MAX ----
MEAS 5C58
MIN 5140
STS OK
ID 0D
MOD $10
MAX 804B
MEAS 8005
MIN ----
STS OK
ID 0D
MOD $10
MAX ----
MEAS 8005
MIN 7FD4
STS OK
ID 0A
MOD $10
MAX 3B6
MEAS 1C
MIN ----
STS OK
Test $0A
ID 01
MOD $10
MAX 96
MEAS 00
MIN ----
STS OK
ID 42
MOD $10
MAX ----
MEAS 2715
MIN 2710
STS OK
ID 13
MOD $10
MAX 3A98
MEAS 4E2
MIN ----
STS OK
ID 04
MOD $10
MAX ----
MEAS 00
MIN 00
STS OK
ID 07
MOD $10
MAX ----
MEAS 258
MIN 258
STS OK
ID 48
MOD $10
MAX 8064
MEAS 7FFD
MIN ----
STS OK
ID 0A
MOD $10
MAX 00
MEAS 00
MIN ----
STS OK
ID 0B
MOD $10
MAX 00
MEAS 00
MIN ----
STS OK
ID 0C
MOD $10
MAX 00
MEAS 00
MIN ----
STS OK
ID 0D
MOD $10
MAX 00
MEAS 00
MIN ----
STS OK
Test $0C
ID 60
MOD $10
MAX 8090
MEAS 7FD4
MIN ----
STS OK
Test $0E
ID 11
MOD $10
MAX 2D
MEAS 00
MIN ----
STS OK
ID 12
MOD $10
MAX 2D
MEAS 00
MIN ----
STS OK
Modules Present
Module $10: VPW
not sure what these tests at the bottom represent but i noticed the first one reads high.
MAY03LT
Delmarva
kawaholic said:
P0335 ENG $10
Malfunction
CURRENT HISTORY MIL
FREQ REPORTED FIX
1-Replaced Camshaft
Position (CMP)
Sensor
ALSO REPORTED FIXES
Converter(s)
2-Replaced Fuel
Pressure Regulator
3-Programmed
Powertrain Control
Module (PCM)
4-Repaired
Powertrain Control
Module (PCM)
Wiring
P0335 MOD $10
Malfunction
CONFIRMED
FREQ REPORTED FIX
1-Replaced Camshaft
Position (CMP)
Sensor
ALSO REPORTED FIXES
Converter(s)
2-Replaced Fuel
Pressure Regulator
3-Programmed
Powertrain Control
Module (PCM)
4-Repaired
Powertrain Control
Module (PCM)
Wiring
I'm only going to cover p0335 since p0336 is intermittent.
Conditions for Setting the DTC
The PCM detects there is no signal from the CKP sensor.
I noticed that you used a duralast crank sensor. I would test it first, both after the engine has been sitting and when the engine is hot. The manual doesn't say what the pcm interprets an out of range signal to be, but I guess it sees it as open.
Unplug the grey pcm connector and read the resistance through the crank sensor.
If it checks out ok, next would be a resistance test on both the resistance and signal leads from the pcm to the crank sensor while wiggling the harness.
Also. Mooseman has some pretty good service manuals, he's got a link to them in his signature.:cool:
Which are right here :biggrin:
V
V
V
V
V
V
V
V
V
V
kawaholic
106
Thanks, I went back and dug up what I came up with when it still wouldn't start.
Pretty sure I had the same results with the new sensor. Can't say for sure whether I tested the harness with the sensor plugged in but I don't think I did. I'll definitely do that and report back. I KNOW I checked each wire for continuity from the pcm to the sensor wiggling everything and it all checked out.
Thanks for the heads up on the manuals, I'll check that out.
kawaholic
106
MAY03LT
Delmarva
I couldn't find a spec for the sensor itself, and I don't know how much resistance they consider in the wiring for the 500-1k test either. If your test results come up nothing obvious, I'll copy/paste the entire p0335 flow chart. (There really isn't much else, asides from replace pcm or crank sensor).
kawaholic
106
That's been my understanding and I've replaced BOTH.
It appears I may have a wiring problem. My plug is a little different than the one in your post but i pulled the back cover off the plug to locate the purple and yellow wires. Not getting any reading. Unplugged sensor to do a continuity test on the wires from plug to plug. Not getting anything there either. I KNOW I had continuity last time I checked this when I changed the sensor and the pcm... <SIGH> I'm pretty sure I'm getting contact with my probes but it's so hard to tell. Those damned terminals in the plugs are so small. It's kind of tough trying to do this by myself, reaching down by the sensor with one lead and probing the plug at the pcm with the other. I even went as far as grinding down the tips of my leads so they'd fit in there better. Can't get a reading on either wire. Tried using a piece of safety wire as a jumper down at the sensor plug so I could just probe the pcm plug, nothing that way either. My meter could probably use a new battery but I've tried it on other pieces of wire and metal I've got laying around and I've gotten readings on everything else. I guess if I look on the bright side, once I can be confident I have good connections between the ckp and the pcm I SHOULD be good to go. I THOUGHT I already had that though. LOL
The thing that's really got me scratching my head right now is, if I'm not getting a crank signal to the pcm how has this thing been running for the past year??? :crazy:
MAY03LT
Delmarva
This isn't the first time I got burned by not crossing the OEM online information to the shop manual. 99 times out of a hundred and this thread is that lucky one time. My apologies.:redface:
What they want you do is, leave the crank sensor plugged in and do the test through terminals 17 and 18 of the connector. If it passes the initial 500-1000 test, it will be easier if your meter has an audible continuity beeper, so you can keep an ear on it as you wiggle down the harness.
Something that happens a lot is when there is damaged wiring inside the insulation. I've seen wires get totally severed inside the insulation and the insulation itself is the only thing that keeps them touching. You do the continuity checks, everythings cool, and riding down the road, boom, it happens again.
kawaholic
106
HAHA On a long shot I decided to try the other plugs and found them in the black plug that plugs into the middle of the pcm. I left the meter on the yellow wire at the ckp and just started probing the other end until i got a hit. Did the same thing for the purple wire. I'm getting 745 ohms through the ckp WHEN I get a good connection. It looks like the weak link is in the plug at the ckp. I'm sure I didn't help it any by probing into the plug. I guess I need to see if I can get those pins to make a better contact or replace the plug...
kawaholic
106
No worries...
I hear ya.
I've got a DECENT connection at the ckp now. I'd rate it about 85% to where it should be. I took a pick and bent the tabs inside the plug. I can wiggle everything without losing my reading at the pcm.
I had the battery disconnected for a while today because I needed to clean the throttle body. Cleaned and oiled the air filter and cleaned the MAF while I was at it.
Once I got that connection squared away, I buttoned everything up and tried to fire her up. Didn't want to start right away, took about 8 cycles with the key before she finally fired. First time I hit the gas she cut off. Wasn't warmed up and the fresh oil on the filter might have had something to do with it. Hit the key again and she fired right up. Let her get up to temperature, blipped the throttle about a dozen times and everything sounded good. Took it for a spin and she felt REALLY good until I got about three miles down the road. I was just cruising along about fifty mph when the tach dropped out, then I noticed the oil pressure dropping. Thought I was going to have to pull to the side of the road until I noticed the oil pressure coming back up. Headed back to the house, drove it pretty hard and she never skipped a beat. Came in my driveway sideways...LMAO... Cut it off and on three or four times, tach stayed at zero and the check engine light came on. C0327 was still in the history (that was the only one there before the test ride). When the light came on, there were three p0335's, the first one read as current/ history/ mil, the second one read confirmed and the third one read pending. Pulled the plug at the pcm and got 895 ohms on the ckp. Wiggled the plug, pulled on the wires and never lost connection. Plugged it back in and fired it up. Tach was working again, cut it off and on another four or five times, tach worked each time and the MIL stayed on. That's where I'm at and I'm going to bed...:biggrin:
kawaholic
106
I'm hesitant to say this is fixed but everything SEEMS to be back to normal. I didn't drive it much the other day, when I did I was driving like grandma. I drove it some more yesterday. Drove it HARD pretty much everywhere I went. She performed flawlessly and didn't protest at all. :cool:
I'm still a little leery about my connection at the ckp. I'm thinking about hitting the local U pull it yard and see if I can find a new plug to splice in or maybe even just replace that part of the harness from the ckp to the pcm.
If someone has a source for new pins/connectors that don't cost a small fortune I'd probably go that route. I'd like some instructions for removing these pins from these plugs too, if anyone has any.
MAY03LT, I REALLY appreciate you making me go back and address the ckp and the wiring. I was confident there was no problem there but it appears I was mistaken.
One other question, should I get another CASE relearn done? No biggie if I do, got a friend of a friend that works at the caddy dealer who did it for me when I replaced the ckp and the pcm. Strange thing is, even after the CASE relearn, the tech II wasn't coming up with anything even though I was still having these problems... :crazy:
MEHMET ONUR
