Without knowing precisely WHAT sort of Aluminum Plates and Shaped Pieces you intend to use for making Modified Intake Manifold...
Why not try Brazing With Aluminum Rods" ?
You could practice welding up a Test Box that you can install either a Pneumatic Fitting into and either fill the container with Water & some Compressed Air and increase the pressure until it FAILS ...and/or put in an AC Vacuum Fitting and us an HF 2.5 CFM Vacuum Pump to pull enough of a Vacuum to collapse the Test Box...and see if the Welds HOLD.
If this stuff is STRONG enough to hold the shape and NOT get above 500 Degrees Fahrenheit...
Using Alumalloy Rods might prove to be the Inexpensive Solution:
This approach is
One Hell of LOT Less Expensive than having to buy a pricey "TIG RIG" at an Air-Gas Counter while you empty out your wallet... and THEN some. It follows on that you'd have to learn and practice the Basics of TIG Welding while using Mixed Gas to the proper levels to TIG Weld effectively.
But with this alternative, you would have very little to lose by experimenting with this idea using some scrap Aluminum Plates, some 1/8" Alumalloy Welding Rods and some MAPP or Propane Gas and using a Typical Propane Torch...
or better yet, for more control...Get the Pistol Grip version with an extended hose:
But... If you've
"Got The Gold Ingots" to drop on some heavy weight TIG Welding Apparatus like the PrimeWeld Machine shown below... the VERY BEST Instructor on the Internet for How To TIG Weld Aluminum is THIS Dude.
He has a Dedicated Welding School on line called
"The Fabrication Series" that might be worth investing in... or find a stack of his Training Videos...Download them all and Study to your Hearts Content.
This Next Video is a PERFECT Example in TFS #5 on "
How to TIG Weld Aluminum Coupons" of the same Gauge and type of Aluminum Plates needed for virtually ANY kind of Aluminum Container Fabrication:
