- Aug 29, 2013
- 16
Hi everyone, hay I have a 05' Chevy Trailblazer EXT LT with a problem. Started to notice the truck running ruff in idle sometimes stalling out. Then it lead to struggling when accelerating but if I step on the gas a bit and give it some power it subsides and all seems ok. I've cleaned out the throttle body replaced the air filter checked the spark plugs and still this problem persists. I've searched around these forums and others and found a lot of similar problems and a suggestion that it could be my #2 upper Oxygen sensor gone bad. Anyone have any ideas if this could be the cause of my problems. Also had a local auto parts store run a check as the Check engine light came on just the other day and got a code of P0098.
Code Definition: Intake Air Temperature Sensor 2 Circuit High Bank 1
Couldn't seem to find much info on this code other then the incoming air is high.
Any help and suggestions?
Thanks in advance!
Thanks in advance!
