What are the signs of a PCM going or gone bad?
Getting random start vehicle issues were I get P0651 and P0107 codes. The map sensor is brand new also installed new Throttle body, new gas pedal with the sensor, New fan clutch and water pump. Yesterday I drove the Trailblazer and stopped at the store for 5 minutes returned and the Trailblazer would not start got the P0651 again. To get it started I had to unplug the fan clutch plug and clear the codes then it started and plugged in the fan clutch again no codes since or issues since. This has happened two times before the wiring to the fan clutch seems on and wires are not crushed.
Could this be a bad PCM or Wiring harness maybe?
How or what wires do I check on the PCM to make sure the PCM is putting out the correct 5 volts for reference?
Don't want to buy a PCM if I can avoid it and understand you have to have a relearn for the cam shaft positioning sensor and let the vehicle set with the key on for the security system to sync up with a new PCM for 30 minutes if I was told correctly.
Any diagrams on wiring or advice is appreciated.
