1. We are working on the forum's attachment system. Attachments and avatars will be intermittently affected over the next 24 hours.
    Dismiss Notice
05 rainier won't start
Discussion in 'Technical Discussion' started by Amarks86, Aug 9, 2017.
  1. Amarks86
    Amarks86 Member
    8
    0
    This is my first post so please bear with me. 2005 buick rainier 4.2 won't start. It was driving fine when i parked it, next day nothing. No crank, no start. Battery has 12.6v, all the fuses look good, i replaced the ignition switch, still nothing. I can pull the ignition relay and stick a paperclip in the ports and it'll start right up (with the key turned on) but when i pull the clip put it shuts off. This makes me believe the starter and solenoid are good. Am i missing something or does anyone have an idea?
  2. Sparky
    Sparky Moderator
    10,607
    5,412
    If you bypass the relay and it works, it makes me think the relay is no good.
    djthumper likes this.
  3. Amarks86
    Amarks86 Member
    8
    0
    Would that make it shut off when i pull the clip out and break the circuit?
  4. budwich
    budwich Well-Known Member
    494
    82
    how about testing the relay to see if it is indeed any good.
  5. Amarks86
    Amarks86 Member
    8
    0
    I tested it an it clicks but ill try replacing it
  6. budwich
    494
    82
    testing usually means operating AND measuring with a meter to check results. Just hearing a "click" doesn't really mean much.
  7. Sparky
    Sparky Moderator
    10,607
    5,412
    It can click, but the contacts inside may not be passing current.
  8. Amarks86
    Amarks86 Member
    8
    0
    Put a new relay in, no change
  9. budwich
    494
    82
    so you when you put in the new relay, do you hear the click?
  10. Amarks86
    Amarks86 Member
    8
    0
    Yes, it clicks but that's it. No other sound from the engine
  11. Amarks86
    Amarks86 Member
    8
    0
    Found in the rear fuse box the tbc4 fuse is blown. I replaced it and it blew again. Could this be the problem and what would be causing that?
  12. Matt
    Matt Silver Supporter
    2,618
    1,145
    It most likely is and there's a short somewhere...time to start tracing wires.
  13. Amarks86
    Amarks86 Member
    8
    0
    Any idea what wires are associated with that fuse?
  14. Matt
    2,618
    1,145
    None at all, I'm sorry. You might want to download the schematics that @Mooseman has posted. You should be able to trace them from that.
    Tiggerr likes this.
  15. Mooseman
    Mooseman Moderator
    10,531
    5,045
  16. Amarks86
    Amarks86 Member
    8
    0
Share This Page
