- May 15, 2014
- 16
I just got an 05 Envoy last night. I forgot to wash the windshield and today I went to use it and nothing. I checked both front and rear and neither of them spray. My truck is not equipped with the headlight washers.
I checked the washer level and I can see the solution. I then started looking around and noticed that the green taped connector to one of the pumps was not plugged in. I got my volt meter and had it ground and when my wife hit the switch I do not get any voltage. I am assuming I should see something like 5 or 12 volts on this motor? I also see the blue taped pump is plugged in but the rear is not working as I had mentioned.
I did replace the fuses and verified the relays are in place. I am new to these trucks but would love a little guidance. It appears maybe I have a short or bad grounds?
Thanks!
Kevin
Thanks!
Kevin
