Was running great, turned off and came back in 20 won't start. Acts like a kill switch, turns over well, pump runs, won't fire. Disconnected battery, reset alarm, same thing. Tried starting fluid, no fire, acted flooded. Electronic? Noticed Reduced Engine Power light comes on after I stop cranking a couple times. Don't know if that is usual for no start. Tried in neutral to rule out start switch. Checked fuses. Did not have any issues beforehand. Last summer had occasional issue with a dead stop at idle, would fire right back up.
Just replaced Ignition switch, no change. Pedal assembly next???
