04 TB temperature needle drifts to the right when going up a hill
Mektek
656
FL
I had similar symptoms when I had radiator issues. It looked good - but the fins were corroded and thin like aluminum foil. A light touch and the metal would flake away.
If some of the internal passages are plugged, it would also cause these symptoms.
gica
135
Cali
This radiator is off the market from Amazon it doesn't have 10k miles on and I always used the dex on it. Can it be that sensitive? I have had many cars and never have I seen an off the market plug up from using the wrong combo of anti freeze.
When I give it 12+ V on the white it does cool it down.
Is there a way to hook up a 12V potentiometer to control how much voltage the white wire gets? Instead of the full 12V+ just to use it based on temperature.
TJBaker57
2,900
Colorado
couldn't find on for fuel level
With the crossed up thread subjects I may have posted this elsewhere but anyway.....Fuel level that works for our trucks is not in Torque by default. But it is here at post #31 of More Pids for Torque...
TJBaker57
2,900
Colorado
So I finally got the app to see the bluetooth adapter and these are the displays I got. I couldn't find on for fuel level. Found fuel remaining.View attachment 95416
The PID torque is using here for fuel level is not supported in our trucks. Use the PID details provided in the "More PIDs for Torque" thread. You will need tonadd the PID manually through the setting menu item.
It has happened where the dex gelled up when mixed with the green stuff. Really nasty mess. If you used only dex and distilled water with it if it wasn't pre-mixed, there shouldn't be a problem.
Unless the aftermarket rad was of such inferior quality that it has less or smaller tubes and/or less fins, it should work fine. I had an aftermarket rad in my '02 that worked fine. I even kept it as a spare in case my '07 ever needs it.
I don't know if a potentiometer would work correctly with the fan clutch as it was designed to work with a PWM signal. Some in the past have wired a switch to the white wire to give extra cooling when required. It shouldn't require modifications like this. Have you tried swapping the relay/module with the headlight one? They are the same.
gica
135
Cali
Both relays are brand new.
The other day the fan started to do the high rpm sound in the morning again. Didn't do it for awhile. It does it untill it worms up. That was different.
So I ordered both the AC Delco radiator and fan from Amazon and will install when they get here tomorrow. If they don't do anything different I'll just return them. I am hoping at least the fan to be more involved as this seems to happen only sometimes on the flatland but mostly going uphill. Maybe it doesn't get triggered. Even at idle with AC on ot takes awhile to get to 228.
Since you mentioned this, haven't given much thought to it but reminds me of mine after a guy in an Explorer tore the nose off my Envoy, nearly totalling it.
Among many items replaced, one was the radiator and ever since then if I'm towing a decent load, maybe 3K lbs, the temp will climb a couple ticks past 210 and I dont remember ever the temp nearing 230 deg.
The new radiator does not have the drain port on the passenger side which I miss.
So this begs to question, the quality of the OE radiator and/or the size of the cooling passages. With the original radiator, it was rare the needle went more than a tick past 210, but now 2 ticks past 210 is the norm when towing, even an empty trailer @ 1400 lbs.
gica
135
Cali
The PID torque is using here for fuel level is not supported in our trucks. Use the PID details provided in the "More PIDs for Torque" thread. You will need to add the PID manually through the setting menu item.
Thanks for that TJ
Also do you have the PIDs for the fan? Thanks in advance
gica
135
Cali
The fuel and oil PiDs don't work for me. The AC high pressure and TWC TEMP CALCULATED DO.
I know it could be extra work but could you replace one, try it, and then the other? It would be interesting to see if one or the other actually makes a difference. We could make some bets. I'm betting on the radiator.
TJBaker57
2,900
Colorado
I didn't see the fan ones. Mine is a 2004
Fan speed is post #1 of the thread. Desired Fan speed is post 2 of the thread. Being the first posts of the thread it looks like I had not started listing the parameters seperate from the text but they are right in there.
gica
135
Cali
I completely forgot about my Autel MaxiDiag Elite MD802 scanner that I put away with all the multimeters I have and completely forgot about. So this thing can read everything. If it did bi-direction it would be the best pro scanner for less. I can read every possible system monitor. Tranny, evap, engine on three different folders etc. It shows the fan desired and actual speed, all the trims, injectors, temps, injectors, cylinders, EVERYTHING.
So what should I look for when I get the higher temps? I know probably Fan desired speed, actual speed, RPM, car temp, trims long and short. But what about the AC High pressure I read that it also affect temps. Too bad I cannot select the monitors I want like in Torque Pro. But I can film it and show it while scrolling.
Now I wonder if the older Autel DS708 which is bi directional and half the price of the DS808 on eBay is any good at controlling functions? Wish I knew someone that still uses it. Cannot be that bad. The Autel MD802 is about the same year and it's complete as far as scanning functions but no bi directional.
gica
135
Cali
I just read a bit on Dexcool and the issues that include corrosion, overheating, gel build up in the radiator manifold damage. So did any of you change to no DeX coolant if so what's the best coolant (Prestone Complete?)
And how to flush the old completely. Just asking.
Dexcool is fine as long as you don't mix it with anything else, including so-called "universal" coolants. There were issues in its early days but have since been sorted out. And since it's a long life coolant, you won't have to worry about it for a while unlike the green stuff.
Reactions: TJBaker57
gica
135
Cali
50/50 is better for heat dissipation. 60/40 would be for freeze protection in the high north, higher than me even. Think Alaska. The pre-mixes are usually 50/50. Water dissipates heat better than coolant.
From a post in that same thread:
Dex-Cool is used in MANY manufacturesr vehicles under Many different brand names.
The problems is not Dex-Cool or GM's
Dex-Cool is an Organic Acid base formula.
It is pre-mixed with Distilled ( mineral-free water )
The problem accures when shops and vehical owners mix tap water with the coolant.
Tap water renders the corrosive qualities of an Organ Acid based coolant ineffective.
I don't use it or any other organic acid based coolants in anything that that I own and have to service. However Dex-Cool will work fine for years in any vehical as long as it is mixed properly with Distilled water.
If you own a vehical with these type of coolants there is no need to drain it unless you or someone else has added tap water.
Ethylene Glycol ( The Green Stuff ) still works great and can be mixed with tap water.
Your choice. Just be damned sure that ALL the orange stuff is completely flushed out.
gica
135
Cali
Ok so I filmed while driving there are 3 clips and they are 123, 124, 125.
One is from when I first started driving and the last one when it was 216. It shows fan speeds
There should be a mixing ratio chart on the container. Follow their recommendations. There's all sorts of school of thought out there, some even going to a 90-10 water-coolant mix. Water Wetter is a product I sometimes use to help with heat transfer.
gica
135
Cali
What is the best way to get all the orange out. Since you cannot use a hose to flush.
I previously used prestone GM decool approved. Don't remember flushing before.
I have to buy some distilled water from Walmart like 6 gallons.
It's probably the same. They can't "call" it Dexcool because it's proprietary to ACDelco but can say it's "compatible" to it.
gica
135
Cali
Ok so how would you flush. Keep adding water and let it warm up? Empty radiator redo?
gica
135
Cali
So I fixed the gas tank a few days ago as I mentioned before the inlet valve was leaking as it does on most of the trailblazers giving codes. Mine was P0442. Well today the EVAP monitor finally went through and I have no code anymore. First time in many many years.
One down and one to go. Tomorrow I will install the new AC Delco radiator and/ or the AC Delco fan. Hopefully it will cure the damn heating issue. I need to tow my jetskis and /or boat to the lake and there is a hill. Crossing fingers.
By the way I looked at the long and short trim values and the highest I got today with or without AC uphill or not was -11.2 once at idle. Most of the time it was -3 to +2 for the long trim while driving, it went to -10.2, -9.4 and back to 2, 3.
Is that decent?
gica
135
Cali
I replaced the radiator and fan could not test drive it because the fan is doing the airplane mumbo. It's freakin loud when I press the gas. Is there anything I can do or is it a dud. This is the Ac Delco Bear shit it pisses me off.
gica
135
Cali
Ok so I actually took it for a drive and the airplane sound subsided when the gears changed. Tomorrow I will take it for a drive and see what changed. This fan is really hard to spin by hand compared to the other off the market one.
TJBaker57
2,900
Colorado
It is considered normal for the fan to require as long as 2 minutes at no less than 2000 rpm to disengage and thus quiet down.
gica
135
Cali
It almost tripped me out last night.
So I drove the car with AC today and noticed some differences. The temp did not go past 201. At idle it was oscillating 198,199 to 201. On the freeway 196,198. The fan though shows different readings than the cheaper equivalent one.
Desired speed is always at 300to 400 but Fan speed goes from 450 to 1000. I cannot feel that though. I never got those readings with the old fan. Not at 201⁰. I will upload a video showing the fan speed driving on the streets from warm up at idle. You can compare with the other videos on Dropbox.
Haven't been uphill yet.
10,685
My guess would be the rush of air through the radiator when driving at speed, is contributing to the fan spinning, in addition to the bit of residual friction from the clutch.
gica
135
Cali
Oh this AC fan is really tight cannot spin it freely by hand like the other one. The air has nothing to do with it. This is all belt driven and some computer driven. The other fans were cheap ones and the belt did not spin them properly too much free play. It's clear.
But I have to drive it on a hotter day. Today it was 82⁰ only and on flat land it did not go beyond 201⁰. On the little
But steel hill I went it took it up to 207⁰. Again all very different than before. I hope it stays this way.
MEHMET ONUR
