yoshi's build 05 TB
xavierny25
6,324
Staten Island, N.Y
yohshua said:
here are some more shots for you guys so you get a better idea
also they don't give you anything for the cargo cover you keep what color you had before
this pic came out bad when i took my floor mats off the color is solid not two toney
passenger area,
cargo area im gonna throw a weather tech on this and it should look better :smile:
I have a suggestion for that cubby lid. Some 1/2 inch mdf little padding and audio grade car fabric or what ever they wanna call it. It's good stuff I re wrapped my sub with it aswell as the cubby cover. And I'm sure the color will match up better with your new carpet then my beat up one..uploadfromtaptalk1443229826715.jpg
Reactions: Capote and yohshua
yohshua
40
Thats a great idea I have to give that a try once I get some free time
yohshua
40
small update checking out hid in the low beam got to say it is a night and day difference from the stock lights and with great cutoff.
Also once my order comes in im gonna try my hand at window tints ill make sure to post that up
yohshua
40
got some new things added.
front driver/pass window tinted to match the rear and led install in the front dome lights.
the pic makes it look alot darker the front in person match the back windows good at 20%
also this is my first time using pre cut tint and i found its alot easier to just take the door panel off that way you can get the edges in
last pic shows abit of a mess up but it cant be seen without looking for it so all in all for a first time i think it went good
yohshua
40
been a while sinse I last updated just done some work on the rear power to start running a new switch setup. Also finally added in a good cargo area light.
before and after rear power,
The cargo light is set on a mercury switch for auto on/off as well as a cut off for times you dont want the light to come on,
Capote
24,227
Atlanta, GA
Digging that cargo area light mod man:2thumbsup:
madd1
1
florida
As to the carpet .let it sit out in hot sun for a bit then install. helps with box wrinkles. acc carpets are oem
Mike . upholstery specialist
Playsinsnow
9,727
0_0 i know i hope after time it will smooth out or again with a mat over it i wont notice anymore
So how is the carpet on the floor holding up? What do you think of the quality?
Gerbil21
839
The carpet has held up just fine, no difference since it was installed. The quality is fine as a aftermarket replacement but definitely not a oe style carpet. All in all it was worth it, especially since the carpet was real bad.
But if your not in any hurry then I would suggest asking for a sample and seeing it in person before committing to it.
yohshua
40
Great build! What lights did you use for the interior lights?
for the inside dome lights i just used 194 led off amazon i forgot what brand and the cargo light was a maxxima m42206 also from amazon
I know i haven't posted here in awhile as i have moved up to a 05 tahoe but i still have the tb
Firebaugh86
