600th POST ..............
Wow, what better to have your 600th post be the 'Top Secret Project' you were working on!!
Anyways as the mod funds are at an all time low at the moment, I have been using anything and everything I can find to try some new stuff. Recently I made a charging stand for my Microsoft Band 2, using some MDF wood we have lying around. It turned out pretty well so I thought I could put my woody skills to another use.
Here came the wireless charging idea for my TB once again....
I started out by messing he size of my largest cup holder, behind the gear shifter. It's where I always place my phone, so that naturally would be where I'd like to put the charger.
Measured out the size of the cup holder and cut a thin sheet as a base
Took another piece and cut the bottom part in a slant cut to provide the stand for the charger and phone to rest on. The charger is pictured above. It's a Belkin one, and one I have had problems with ever since I bought it . You can also see me experiment with spray painting the piece of the wood at the bottom of the pic
Reinforcement at the base, and got the top part wrapped with the carbon fiber vinyl I have lying around the house
Tried mounting the charger itself, to the stand, cause my mom didn't want me breaking into the charger
It was too wide to fit in flush with the cup holder, so it was certain to be broken into. Which was a fight to the finish. Only one of the screws at the bottom came off, rest was just a lot of strength and sound of plastic breaking
With the plastic off and the coil out, my suspicions were right. It was a shitty single coil charger in such a HUGE plastic body. I have Nokia triple coil chargers in a sleeker and much smaller body than this
Needed some more reinforcement for the stand, the charger is held to the stand using some aluminum wire. I tried screwing it etc.. Just couldn't get it to work. So wire it was.
Added some extras here, just to keep the stand nice and flat. Didn't turn out that well, and I think one of these pieces just fell off yesterday. Will need to rethink about these
A last minute modification after testing the stand. The phone would slack when put into the cup holder and miss the coil. So had to put this small piece to keep it upright with the coil to charge.
This is how it looks when in the car. The cable is coming through the rear cig lighter. No custom wiring or anything done, just a USB to micro USB cable. This was one of the main reasons I bought this charger was because it worked through micro USB. I have a spare Nokia Wireless Charger, but it's cable is so proprietary that I could find one that had a USB at the back.
Anyways it does work now. Much better than before. Although there seemed to be a hiccup when I went out yesterday. I am going to try to remove the rubber cup holder base and see if it will improve the performance.
ANd if you guys have any ideas on how to improve this please let em know for sure
