Winch install (installed with pics)
Discussion in 'Off-Road' started by Mirror, Nov 27, 2016.
  1. Mirror
    Mirror Well-Known Member
    261
    21
    I just picked up a 10,000lb winch but i don't have a custom built bumper yet. Was curious if anyone has ever done a temp winch install with only the factory metal bumper installed.
    I don't have a front hitch and the plastic bumper cover is removed.
    Also for those that have a winch, has anyone installed the servo box under tge hood, if so post pics please.
  2. HARDTRAILZ
    HARDTRAILZ Moderator
    42,908
    10,348
    The stock metal bumper support is wholly inadequate to use for mounting any winch.
    Just buy a piece of plate and bolt it across the frame rails if anything.
    I thought about moving box under hood, but could not find a real reason for it.
  3. Mirror
    261
    21
    Ya i was thinking of the plate idea but would have to find longer bolts to make up the difference since i need the bumper on to be street legal and still need my hooks.
    I do a lot of water crossings so the added protection of the box being under the hood guarantees no water gets in it.
  4. HARDTRAILZ
    42,908
    10,348
    Done a number of water crossings and never had an issue personally, but seems several rigs stick it under hood. should be as simple as extending the wires and putting it someplace with easy plug access.
    To get the plate flat mounted to the frame you will need to remove the lil nub sticking up with a grinder so you make up some there, but be sure to grab at least grade 8 if you cant get some 10.9 for it.
    You may want to look into a pre made plate since you will need somewhere to mount the fairlead anyway.
  5. Mirror
    261
    21
    What thickness of steel should i look for?
  6. djthumper
    djthumper Administrator
    13,385
    3,014
    Admin Post
    3/16 minimum
    HARDTRAILZ likes this.
  7. HARDTRAILZ
    42,908
    10,348
  8. Mirror
    261
    21
    Did it with a sheet of 3/8 steel and mounted the solenoid box under the hood. Just have to run the control wire into the cab and hard wire.
    Add ons to the bumper will be added gradually.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Derrick Rucker and Blckshdw like this.
  9. Shdwdrgn
    Shdwdrgn Well-Known Member
    541
    62
    That looks really good with the control box removed and mounted under the hood, nice job! I've been looking at the Badlands winches for awhile now. They don't have the 10k pound model here, but they do have a 12k which looks exactly the same. Been selling for $289 for awhile now, but I offroad so infrequently that the only thing I can justify a winch for is the possibility of going off the road during a snow storm. Still I'm *really* trying to justify it... :smile:
    Does the fairlead mount really need much strength to it? I had been thinking it needs something pretty hefty, but if what Mirror has is suitable then I can easily work that in to my setup with the sides bolted to the pushbar.
Share This Page
