Why is the LS engine so good??
northcreek
3,319
WNY
Found this to be informative and interesting...Mike.
GM did it good when they engineered this engine.
DocBrown
501
This was a little too long to watch the whole thing. But what I did see was interesting. So if he talked about the history of it I missed it. One of things that make this engine so good is over 60 years of engineering have gone into it. Granted it's not your father's small block V8. But every generation had improvements, and everything has been a learning experience for the engineers.
littleblazer
9,265
I mean it's just the heads... the rest is based off of sbcs and aftermarket hop ups. Make it breathe and it'll be faster. :2thumbsup:
I remember reading somewhere that the LS shares nothing with the SBC. The lifters being under the head is also very different.
Reactions: northcreek
Paul Bell
460
Actually, the lifters themselves are interchangeable with a SBC.
northcreek
3,319
WNY
I totally agree, the guy mentions the many improvements over the old small/big blocks of old.I mean it's not even a "V" it's a "Y" block.
I thought the part about the stock intake manifold being superior to the after market stuff was eye opening too.
littleblazer
9,265
I'm just going off of principal. It's still based off of a sbc. Push rod ohv engine. It's very well designed and optimized for what it needs to do. Technology wise the atlas was light years ahead of it when it first debuted. By 05 it was about the same.
northcreek
3,319
WNY
If I'm reading this correctly, it makes the point both ways :undecided: Mike.
LS based GM small-block engine
From Wikipedia, the free encyclopedia
Overview
Manufacturer
General Motors
Production 1997–present
The GM small-block engine family is an engine design intended as the primary V-8 engine used in General Motors' line of rear-wheel-drive cars and trucks. The GM small-block series was a "clean sheet" design with only the rod bearings and bore spacing in common in terms of shared parts and dimensions with the classic Chevrolet small block V8. The basic layout owes a good deal to the essential concept of Ed Cole's original small-block design of 1954-55, though the small-block engine also uses design cues from Buick, Oldsmobile, and Pontiac engines. Some small-block engines are all-aluminium, especially the performance oriented engines, while others use cast iron blocks. The aluminum block engines use cast iron cylinder liners.
chirobo1
