1. We are working on the forum's attachment system. Attachments and avatars will be intermittently affected over the next 24 hours.
    Dismiss Notice
Wheel offset question
Discussion in 'Wheels & Tires' started by Darkrider_LS, Aug 14, 2013.
  1. Darkrider_LS
    Darkrider_LS Moderator
    9,290
    3,211
    Ok figured i would ask this since im looking at wheels again. I am looking at wheels with a 25 mm offset. Would i require spacers to run a tire taller then 30.5 on these wheels?
  2. The_Roadie
    The_Roadie Well-Known Member
    9,924
    2,023
    Admin Post
    You still have to do the math, and also realize every tire is slightly different in terms of diameter (nominals aren't exact) and the edge roundness. Offset isn't enough to fully define the geometry of the relationship of the tire to the upper ball joint. You also have to know the rim width compared to stock. See if you can find out more about the rim width of the proposed wheel, and while you're doing that research, find out what the OEM wheel rim width and offset is. I haven't led anybody through this in quite a while so it will be useful to do it again for the archives here on GMTN.
  3. 06_GATOR_VOY
    06_GATOR_VOY Well-Known Member
    250
    26
    ba-zinga!
  4. The_Roadie
    9,924
    2,023
    Admin Post
    I LOVE to teach people how to fish (and do their own analyses). I'm not so much into just handing over a fish, nowadays. :rotfl:
    nagyiii and BHAMER like this.
  5. Darkrider_LS
    9,290
    3,211
    Great info thanks! The planned wheels are 17x8 with a 25 mm offset. From what I have read the oe wheels are 17x7 with 6" backspacing.
  6. The_Roadie
    9,924
    2,023
    Admin Post
    You got it in one!
    Except for the little detail of now you have to convert backspacing to offset. :wink:
    Oh, I'm feeling generous tonight.
  7. The_Roadie
    9,924
    2,023
    Admin Post
    So see if you can do the math (and show your work).
    You need to measure the OEM tire to see how much it can grow in diameter and not hit the ball joint. And see how much room there is horizontally.
    The new tire and rim are going to put the centerline of the wheel at some location, but the new rim is wider, so half the rim width increase is going to go towards the center of the vehicle and half is going to grow outwards. So the NEW location for the tire edge is going to move horizontally some amount (increase in tire width plus movement due to the wheel offset) and vertically some amount (diameter increase divided by two because what we're interested in is radius, not diameter.)
    Anybody who skipped math because they thought it would never have real-world application can be excused from the classroom now. :hissyfit:
  8. Darkrider_LS
    9,290
    3,211
    Awesome info Roadie! If i am following the chart correctly the new wheels have a 5.5" backspacing. But due to the fact that said rims are also an inch wider then stock and since half of said added width would be on each side of the center line of the rims. The new 17x8 rims would have the inner edge roughly at the same point as the OE 7". Thus answering my question about relation to the ubj. All i really did was gain a wider rim but no outward movement towards the outside of the truck. Thus if i want to go taller then that max 30.5-30.6 tire height i will need to run spacers.
    Safe_CrackerLS likes this.
  9. djthumper
    djthumper Administrator
    13,541
    3,165
    Admin Post
    Actually you gained .5" of clearance...
  10. Darkrider_LS
    9,290
    3,211
    Oh really??
  11. The_Roadie
    9,924
    2,023
    Admin Post
    That's why I advised everybody show your work. If you can explain it adequately, it's likely right.
  12. djthumper
    13,541
    3,165
    Admin Post
    Yep.
    I need to show my work as well?
  13. Darkrider_LS
    9,290
    3,211
    Please do so!
  14. djthumper
    13,541
    3,165
    Admin Post
  15. navigator
    navigator Well-Known Member
    504
    1
    that's cheating, you have to show your math work to get full credit :smile:
  16. navigator
    504
    1
    Larry is right though, you do gain .5"
    For me, backspace is easier to calculate than offset.
    The OEM rim has 6" backspace.
    The new rim has 5.5" of backspace.
    Backspace doesn't care how wide the rim is. If you take the tire width out of the equation, a 12" wide rim with 5.5 backspace has the same ball joint clearance as a 7" rim with 5.5 backspace. The 12 inch rim will just stick out from the fender further.
    Since you gained .5" in backspace that will be additional clearance. You'll have to measure to see if that .5" is enough clearance for the tire you want to run.
  17. The_Roadie
    9,924
    2,023
    Admin Post
    0.5" is what I get too. The rim width is compensated for in the backspacing to offset chart, so it doesn't need to be in the equation twice.
    That said, tire variability can exceed 1/2". The design of the tire might include side lugs for rock crawling that make for a more square corner, or it could be rounded. They can also vary larger or smaller from the "nominal" metric size given in all the tire size calculators.
    Now this thread can be the link we gently/snarkily give anybody in the future who repeats the question without searching first. :wootwoot:
  18. jimmyjam
    jimmyjam Well-Known Member
    1,634
    638
    I'd like my seabass served with a nice mango chutney, thank you :thumbsup:
  19. djthumper
    13,541
    3,165
    Admin Post
    Apparently my math was correct because it worked on my truck. :raspberry:
  20. Darkrider_LS
    9,290
    3,211
    Great info in here for sure. Guess I misunderstood the relation of the new wheels width vs offset. But at least all the above proves I can at least rock a tire taller then 30.5 as long as it is round shouldered.
  21. nieman88
    nieman88 Well-Known Member
    70
    3
    ....you lost me (but thats not hard to do). And I searched here and other sites. Im just very confused.
    im actually face palming trying to understand offset and backspacing...still.
    Dumb it down for me. ...im going nuckin futz
  22. nieman88
    70
    3
  23. Playsinsnow
    Playsinsnow Well-Known Member
    9,724
    1,803
    The following is an excerpt from Tirerack.com
    Hope it helps.
    "The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
    Zero Offset
    The hub mounting surface is even with the centerline of the wheel.
    Positive
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
    Negative
    The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
    If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
    *Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches)."
  24. nieman88
    70
    3
    :duh:
    thanks muchly =)
    Now I can start shopping around.
  25. djthumper
    13,541
    3,165
    Admin Post
    What are you looking for?
  26. Pittdawg
    Pittdawg Well-Known Member
    538
    41
    What about a 25 mm offset wheel with 6x5 to 6x5.5 adapters? If the adapters are 1.5 inches thick, does that mean I would gain 2 inches of offset (that's too much!)?
  27. Darkrider_LS
    9,290
    3,211
    Depends on the specs of the proposed new rims. Let's take the wheels I was looking at for example with their 5.5" back space. With adapters they go down to 4" backspace which as you stated gives you around 2" of clearance. Which seems to be where most of us are after changing rims to aftermarket fsc application wheels. Iirc kyle aka Hardtrailz runs a set up that has him around 3.5" backspace on his wheels. The wheels I'm looking at start at 6 3/16" backspace which with adapters puts me between 4.5 and 4.75 backspace. Or around 1.25" clearance at minimum.
  28. paul2005tb
    paul2005tb Well-Known Member
    129
    18
    question: can I purchase shorter lug bolts to mount to the hub so that when I install my 1.5in adapters there will be no need to grind down my existing lugs ?
  29. HARDTRAILZ
    HARDTRAILZ Moderator
    43,990
    10,853
    1.5 inch adaptors need no grinding....
    paul2005tb likes this.
  30. paul2005tb
    129
    18
    Great news ! Thanks. I assume that adaptors less than 1.5 would come with lug bolts to replace the existing lugs.
  31. paul2005tb
    129
    18
    Im considering a low budget spacer solution:
    1) 1/4 in slip-on spacers
    2) Grind 1/8in off of the upper ball joint knuckle/seat .
    That should get me to almost a 31.0in dia. at 245 with a tame tread pattern .
  32. Tiggerr
    Tiggerr Gold Supporter
    950
    334
    I don't believe i'd go grinding the balljoint seat.
    Don't think I'd do slip on spacer either without using longer wheel studs. Doesn't seem too safe.
    Most do the adapter/spacers. Then they bolt down and you use the spacer's studs for wheels. Think it changes to Chevy truck pattern too. Way easier to find wheels too.
    Better to spend the $ and be safe than shortcut something that crucial. IMHO
    paul2005tb and BlazingTrails like this.
  33. BlazingTrails
    BlazingTrails Banned
    19,409
    10,246
    IMO changing the studs out and using a "slip on" spacer would be stronger and less to go wrong.I would never grind anything on my suspension, (???)
    Good point on the wheel selection, there are so many more wheels for 6x5.5" pattern.
  34. Wooluf1952
    Wooluf1952 Well-Known Member
    2,525
    320
    Grinding the edge of the UCA was pretty common on the OS. IDK if anyone ever had a problem doing that.
  35. djthumper
    13,541
    3,165
    Admin Post
    Slip on spacers are not recommeneded due to you would not have the studs sticking through the lug nuts.
  36. HARDTRAILZ
    43,990
    10,853
    Tons of people have ground the balljoint without issue.
    I ran 1/4 inch spacer on a camaro and had no issues. Check to make sure after 1/4 inch you still have adequate thread engagement and all will good.
Share This Page
