Revans381996 said:
Hi everyone, I just joined the forum today. I have a 2003 Chevy trailblazer with 156,000 miles. I just wanted some advice on what maintenance I should do. I change my oil every 3,000 miles with conventional 10w30. And 11,000 miles ago I changed the tranny fluid and filter. Also just changed my front and rear diff fluid (found out my front diff has a pretty big leak, still didn't fix it) i also cleaned my throttle body to fix a poor idle. I was thinking about changing my transfer case fluid and my fuel filter because I have no idea when they were changed. What are your thoughts? Transfer cAse fluid looks pretty easy but the fuel filter looks kinda difficult because I've never done one. I really want to get this thing to 200,000 miles.
The fuel filter supposedly doesn't need changed on these. "Supposedly" - I changed mine anyways, it is a pain.
I would do the transfer case if I were you, just get it taken care of.
Spark plugs, probably time for new ones.
Check your serpentine belt for cracks and see if it needs replaced.
Coolant flush can't hurt (you'll get differentiating opinions on this)
Check your radiator hoses, never fun when one pops.
Check the water level in your battery
Check the bushings all over. At 156K it's probably time to start replacing some.
If you really want to get into it, check the lower and upper ball joint, break out a grease gun, check your tie rod ends.....
..... actually there is a pretty long list of things you can visually inspect to determine what you should tackle vs tackling just because. You've covered some of the more routine maintenance points already.
ALSO WELCOME TO THE SITE, glad to have you!
